Any idea if and by when the stock firmware (or even for Merlin) for ASUS RT-AX92U will be updated to 388 release?next Asus release
Currently using OpenDNS but not able to successfully use it through DNS over TLS yet.Use public filtering DNS service like OpenDNS, CleanBrowsing, Cloudflare for Families, Quad9, AdGuard, etc. Many to choose from.
How do I verify that DNS over TLS is working?It works properly on Asus routers:
Try here after setting to:How do I verify that DNS over TLS is working?
I can verify that OpenDNS is working by visiting https://welcome.opendns.com
Visiting https://tenta.com/test/ shows TLS Enabled as False.
No idea on Asus. As for Asuswrt-Merlin, @GNUton handles that model in his fork.Any idea if and by when the stock firmware (or even for Merlin) for ASUS RT-AX92U will be updated to 388 release?
Thanks. I have enabled DoT to OpenDNS in my router.I verified that for you already. My test routers are behind pfSense firewall and I can see what's going on. DoT to OpenDNS is working properly.
Welcome To SNBForums
