Intrepid2007
Hello,
I am using the latest available alpha firmware and I was wondering if DNSFilter should work in the scenario below as well??
(this is just an simple example to explain)
All DNS requests from LAN clients should be resolved by 1.1.1.1 (Custom 1):
Windows IPv4 settings use a static DNS (Google DNS in this example)
Now my inderstanding is that the DNS filter feature should check DNS requests and make sure that '1.1.1.1' is used instead...
When I test this particlar example by going to www.dnsleaktest.com, the DNS servers from Google are shown in the results..
Should DNSFilter also work when clients have static DNS servers configured?
Also if I set 'Global Filter mode' to Router, the behavior is the same.
However, if all settings in the LAN client settings are set to DHCP, the DNS filter feature works as expected.
UPDATE:
I rebooted the router and the problem disappeared (all working now)
UPDATE:
