thelonelycoder
Part of the Furniture
The amtm backup function is coming, just not with the next update. It will start with a simple backup function, then features will be added as time allows.
Perfect, Mr. Lonely!The amtm backup function is coming, just not with the next update. It will start with a simple backup function, then features will be added as time allows.
Ah, come again?Hoarders Anonymous might be able to help...
The Lonely Coder = Mr. Lonely. A joke?
On a scale of 1 to 10, my introvert level is 8. Im socially functional and can act normal if the situation requires it. But I need my alone time to recover from too much exposure to in-person interaction.The Lonely Coder = Mr. Lonely. A joke?
You have my total supportOn a scale of 1 to 10, my introvert level is 8. Im socially functional and can act normal if the situation requires it. But I need my alone time to recover from too much exposure to in-person interaction.
I‘m perfectly fine with that, no need to be sorry. My handle reflects one of the hobbies that allow me to charge the battery for the next exposure.
I have two modes that switch automatically. The public and private. I do not waste my time to brood or think about things that I cannot change.You have my total supporteach is like each.
But... Don't be afraid. In a good way, no one "cares" or "notices" anyone. You may think that people look at you or point at you, and that makes you even more introvert, but hey... People nowadays are much arrogant and "don't have time" to care about anyone, so be peaceful and live your life normally as you want, no fears my friend!![]()
(Emphasis set)Also, this is a test of a new image hoster, let me know if the image is not shown
Image fine here.![]()
amtm is a front end for (mostly) third party scripts. While the amtm update function updates its own necessary files to interact with these scripts, it DOES NOT, and NEVER HAS and NEVER WILL update a third party script on its own.Hello.
I'm a bit confused here about purpose of amtm. It allows install and uninstall packages, it shows when new versions are available, but it doesn't update the packages?
What the uu command is for? it downloads the packages, but it doesn't update them, why?
I'm pretty sure when I first discovered amtm a year ago, it did update packages. What I'm missing here?
Which suggests that these scripts can be updated via amtm...Third-party script update(s) available in amtm:
Because uu is the force-update function for amtm, which re-downloads all amtm files. All these *.mod files ARE amtm files. They enable interaction with the third party scripts.so why it redownloads the packages with uu command?
The emai also says to use the u function in amtm to check for updates.so why it redownloads the packages with uu command?
Also, the email sent by Diversion:
Welcome To SNBForums
