amtm amtm - the Asuswrt-Merlin Terminal Menu
That could be the common issue here, I use MiniTool Partition Wizard to format the drive
I'm reluctant to add more filesystem support ATM for lack of time to test these identifiers. Don't want the disk-check to run the wrong test on a disk.
But it you have the time, or anyone else for that matter, change the case statement around line 320 in the disk_check() function in amtm to include it. Then remove and re-install dc to write the new disk-check file.
Be cautious though, your data is more important than the result a failed test....
So @Adamm to expand on the above:
The criteria to run the check is the argument passed on to pre-mount during boot: The device location as seen by fdisk -l
And then the case statement is used to determine if a supported disk is found by: System with fdisk -l
The disk-check also only runs on USB mounted disks, be they thumb drives, SSD's or HDD's. No internal filesystems are checked, like the jffs partition.
Disk /dev/sda: 15.7 GB, 15728640000 bytes
64 heads, 32 sectors/track, 15000 cylinders
Units = cylinders of 2048 * 512 = 1048576 bytes
Device Boot Start End Blocks Id System
/dev/sda1
1 7500 7679984 83 Linux
/dev/sda2
7501 15000 7680000 83 Linux
Forgot to escape the $1 positional parameter in the code, I have pushed an update to GitHub.
Use u and dc twice for the logfile to correctly report the device path the test is run on (it says "install" instead of path ATM).
What's your output of
fdisk -l
Disk /dev/sda1: 30.7 GB, 30752620544 bytes
64 heads, 32 sectors/track, 29327 cylinders
Disk /dev/sda1 doesn't contain a valid partition table
That's unfortunate and may be the cause of many of the disk failures we've seen around here.
Additionally, that error prevents the auto-run of the disk-check.
I do not have a cure, someone with better understanding of filesystems will have to offer more insight and a solution.
A search for the error returns many results.
PS: Come to think of it; this flash drive might actually be formatted using mke2fs on the router itself (because I could not assign a label).
Question,
What I did was install AB-Solution, entware & pixel serv, swap file (from ABS menu), finally amtm & dc
Is it really necessary to avoid issues to do entware>amtm>swap>ab>pixelserv?
Thanks,
Sent from my SM-G935FD using Tapatalk
Question,
Thanks,
The order should be amtm>ab-solution (while in ab-solution install pixelsrv-tls by using "ps" this intsalls entware)>add swap>done.
The above is to avoid issues.
So I spent a bunch of time trying to track down what the issue is here, and the only conclusion I've come to is that the script uses a pretty unreliable method of detection.
I think part of the issue comes down to fdisk limitations dealing with GPT partitions. I'm going to assume you use MBR, or maybe I'm wrong. I tried formatting with a number of tools and even Ubuntu in a VM, each time the same result when it was a GPT partition.
I only copied the code from the original script and assumed it works for most. I certainly never had a problem with my devices.
Maybe there's a better way to detect the device before it's mounted. I have open ears and eyes.
Well I think a good starting point is to see on devices where this does work, are you using a MBR partition or a GPT partition?
How do you tell the difference?
MBR, on all of them.
Will do some testing tomorrow, what should I partition them with?
Some pointers would help.
Naively on the router to check this you would need to download a tool like parted from entware;
opkg install parted
Then run;
parted -l
Which would give a result similar to;
admin@RT-AC86U-2EE8:/jffs/scripts# parted -l
Model: WD Elements 25A2 (scsi)
Disk /dev/sdb: 2000GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system  Name                  Flags
 1      1049kB  2000GB  2000GB  ext4         Basic data partition  msftdata
Mine looks like this using your above commands:
Model: SanDisk Ultra Fit (scsi)
Disk /dev/sda: 15.4GB
Partition Table: msdos
Disk Flags:
Number  Start   End     Size    Type     File system  Flags
 1      16.4kB  15.4GB  15.4GB  primary  ext2
The rest of the results were:
Error: /dev/mtdblock0: unrecognised disk label
Model: Unknown (unknown)
Disk /dev/mtdblock0: 524kB
Partition Table: unknown
Disk Flags:
Error: /dev/mtdblock1: unrecognised disk label
Disk /dev/mtdblock1: 1573kB
Disk Flags:
Error: /dev/mtdblock2: unrecognised disk label
Disk /dev/mtdblock2: 65.0MB
Disk Flags:
Error: /dev/mtdblock3: unrecognised disk label
Disk /dev/mtdblock3: 63.2MB
Disk Flags:
Error: /dev/mtdblock4: unrecognised disk label
Disk /dev/mtdblock4: 67.1MB
Disk Flags:
Just partition any drive with a GPT partition table, then format a ext* partition like normal. Just about every partitioning tool has an option of what table type to use, a quick google with your tool/os of choice will give you a good guide.
FYI; its just the detection that's "broken", the filesystem check its-self works as expected.
admin@RT-AC86U-2EE8:/tmp/home/root# e2fsck -p /dev/sda1
Elements: Backing up journal inode block information.
Elements: clean, 411/488374272 files, 30567798/488369920 blocks
This line indicates you are using MBR (so I also assume the script works for you).
bsd
dvh
gpt    - this is a GPT partition table
loop   - this is raw disk access without a partition table
mac
msdos  - this is a standard MBR partition table
pc98
sun
These are my results in amtm:
 /jffs/amtm-disk-check.log has this content:
 START FILE, --- lines are not part of file
 Tue Mar  6 11:44:51 GMT 2018 Starting 'e2fsck -p /dev/sda1'
 EXT2: clean, 585/940240 files, 351399/3753902 blocks
 END FILE
For me (the script fails):
# parted -l /dev/sda1
Disk /dev/sda: 30.8GB
Disk Flags:
 1      16.4kB  30.8GB  30.8GB  primary  ext2         lba
