XIII
Part of the Furniture
Oops. Should not post that late I guess... Sorry!Wrong thread, but it shouldn't unless a specific IP is blocked its trying to access.
amtm used to work at root prompt, but now I need to type "/jffs/scripts/amtm". Is something changed in the latest version or my installation problem?
If entware installation is detected amtm will symlink its-self to /opt/bin (meaning you can execute it just using "amtm")
Entware and pixelserv-tls, do you have them installed?Im a newbie here. I installed this from the link at the beginning, created the swap file, all good, exited, and when i start it again 3 and 4 both say 'Menu not Available'. I cant remember what those options were however.........
SNBForum Asuswrt-Merlin Terminal Menu
amtm 1.2 by thelonelycoder
RT-AC86U aarch64 384.4 192.168.1.1
SNBForum scripts
1 open AB-Solution
2 open dnscrypt installer
3 update Entware
4 update pixelserv-tls beta version
5 open Skynet
swp delete Swap file /mnt/SNB
dc remove Disk check script
dcl show Disk check log
u update
r remove
a about
e exit
Nope - not installed either of them. Waiting on a new usb3 drive first. they did show up when first installed, I did the swap thing, then exited, then restarted it, and those menu options gone.
Do not select yes dnscrypt will over ride the setting you refer to anyway but as a fail back use something like cloudflare 1.1.1.1 or googles 8.8.8.8 so that if for some reason dnscrypt fails to load you have dns still.I'm currently using all the packages offered under amtm. I have a question regarding DNS
On the router, under WAN > WAN DNS Settings. Do we need to specify a DNS Server or select YES on Connect to DNS Server automatically?
The command it runs is:Hello,
Trying to install AB-Solution, it fails during the internet test: DNS level 3 and Cloudfare. I do have however an internet connection.
I try to install to Susu AC87u with FM 385.5.
The router is behind a cable modem.
The IP address of that cable modem differs from the Asus.
The router takes care of DHCP for the clients.
Can I install AB-Solution?
Raymond
ping -c 2 209.244.0.3
ping -c 2 1.1.1.1
curl -L -s -k -O https://raw.githubusercontent.com/thuantran/dnscrypt-asuswrt-installer/master/installer && sh installer ; rm installer
That command is the same as posted by the coder of the installer.I can't get out to the internet at all until I uninstall it. However, the only way to uninstall it is to run the script - which I can't get because after amtm ran it, it deleted it!
; rm installer
amtm 1.3 is now available
We use essential cookies to make this site work, and optional cookies to enhance your experience.
