thelonelycoder
Part of the Furniture
Done, no version in title now as this messes up notifications for some.Don't forget to update the thread title![]()
Weeeee!
Sure, just use the installer command from the Diversion website.Weeeee!
So we can change ABS 3.0 to Diversion?!
Last one, do I have to fully uninstall ABS3 first? Just to ensure I'm not leaving any leftovers of previous version and ensure no conflicts will happenSure, just use the installer command from the Diversion website.
No need to. See the answer to your other question here: https://www.snbforums.com/threads/ab-solution-the-ad-blocking-solution.37511/page-167#post-426457Last one, do I have to fully uninstall ABS3 first? Just to ensure I'm not leaving any leftovers of previous version and ensure no conflicts will happen
What firmware version is installed? You might have to update to a more recent Asuswrt-Merlin firmware that comes with a newer version of ipset.When trying to manually install Skynet with the url in that forum i receive a error about ipset being to old.
That problem might be related to this error?
Yes. Choose the beta install in the amtm menu.Are we able to install the latest version of Pixelserv using amtm?
/jffs/scripts/amtmQuick question folks.
I had to format the USB drive and reinstall AMTM
However now after the install when I try to launch it from the root
/tmp/home/root# AMTM
-sh: amtm: not found
What is the quick for fix for this.
/jffs/scripts/amtm
Absolutely!is it possible/advised to install amtm after I already installed Diversion and Skynet?
No, this is a temporary thing. If you want to be so adventurous you'll have to figure it out yourself.thelonelycoder, are you going to add an option to the pixelserv beta installer for 2.2.0-rc.3 (prepend "_binfavor=static " )? I suppose you may be waiting for kvic's current rapid pace of development to stabilize before committing changes. I figured I should ask anyways, since AMTM already has the beta installer, but users may not realize there is an 'manual option' to use openssllib 1.1.1 instead.
...also wondering if that was intended to be '_binflavor', hehe.
Cheers,
Kev
Kivc already say rc6 coming out soon. Kivc already say the OpenSSL version is more like alpha testing. Not supposed to be normal operation. You should already know when you are in the test group.thelonelycoder, are you going to add an option to the pixelserv beta installer for 2.2.0-rc.3 (prepend "_binfavor=static " )? I suppose you may be waiting for kvic's current rapid pace of development to stabilize before committing changes. I figured I should ask anyways, since AMTM already has the beta installer, but users may not realize there is an 'manual option' to use openssllib 1.1.1 instead.
Cheers,
Kev
I hear you @kvic !Seems many people are still confused and not clear about the goal of statically linked builds..
Welcome To SNBForums
