amtm amtm - the Asuswrt-Merlin Terminal Menu
This works real well so far! I've tried everything except swap file install as I don't need one. Everything worked! I installed the beta pixelserv-tls the dncrypt installer skynet ab-solution its all good.
Awesome work! this works great, one question, once installed and exit, I can not start it again with amtm?
It did tell you how to start it. If Entware is installed or /opt/bin/ is otherwise present, you can start it with amtm.
In your case it said to start it with /jffs/scripts/amtm
I don't see the swap file install option. Is that just because I already have a swap file installed?
Swap file install is not (yet) part of amtm. This can be done through Skynet.
Yes that works, I’ve only got 3 dirs in my USB root: entware, adblocking and skynet.
Can I just create opt and bin in opt?
What's your output of
which opkg
This is what happens
ASUSWRT-Merlin RT-AC5300 380.68-4 Wed Oct  4 19:03:28 UTC 2017
admin@RT-AC5300-7380:/tmp/home/root# which opkg
/opt/bin/opkg
admin@RT-AC5300-7380:/tmp/home/root# amtm
-sh: amtm: not found
/opt/bin/opkg
Humour me, what is it for:
which amtm
If that returns nothing, start amtm with the jffs command and remove it.
Then reinstall.
And I want to add: The version number 0.1 suggests this is a beta version...
Just did, result is the same? Maybe a rights issue? As I don’t see opt either?
In the terminal, enter
cd /opt/bin
then
ls
About 10 binaries should be listed. One of them called ab-solution.
Also, if you start AB-Solution and enter s, what is the first start option listed?
One more check. Copy and paste this whole line into the terminal, then hit enter.
The return should say foundit:
[ -d "/opt/bin" ] && echo foundit || echo notfound
After I ran the update Entware feature it broke pixelserv-tls start in services-start. I added 15 seconds to the start of Entware and it solved the issue.
For me, the installation command does nothing.
# curl -Os https://raw.githubusercontent.com/decoderman/amtm/master/amtm && sh amtm
