amtm amtm - the Asuswrt-Merlin Terminal Menu
I get that point that's why I specifically asked AFTER we UPGRADE to 384.15........
And by your previous reply, I deduced the FW amtm version will automatically handle the removal part (if that's how it will deal with it) of the regular amtm already installed on it.
When Entware is installed and the firmware amtm is present, the latter should start and migrate. When running the regular amtm install command from the diversion.ch website on a firmware that has the built in amtm version, magic will happen :p
I had the exact same experience
I overcame this by hard closing out of putty via the "x" box and reopening putty and it appeared correctly. The change had already taken place and upon reopening, 3.1.0 was showing.
See that's a the magic Avada Kedavra explanation I was waiting for [emoji1787][emoji1787][emoji13][emoji13]
  • Like
Reactions: a5m
Strange error when updating, see end of below:
 Enter option  u
 amtm 3.0                  by thelonelycoder
 RT-AC86U (aarch64) FW-384.14 @ 10.14.16.1
 The SNBForum Asuswrt-Merlin Terminal Menu
 1  open     Diversion     v4.1.8      no upd
 3  open     FreshJR QOS   v8.8    -> min upd
 4  open     YazFi         v3.2.3      no upd
 5  open     scribe        v2.4.1      no upd
 j1 open     connmon       v2.2.0      no upd
 j2 open     ntpMerlin     v2.2.0      no upd
 j3 open     scMerlin      v1.0.3      no upd
 j4 open     spdMerlin     v3.2.0   <- v3.1.0
 j5 open     uiDivStats    v1.3.0      no upd
 j6 open     uiScribe      v1.2.0      no upd
 ep manage   Entware packages          no upd
 e  exit     amtm          v3.0     -> v3.1.0
_____________________________________________
 Script update(s) available!
 amtm 3.1.0 is now available!
 See https://diversion.ch for what's new.
 Do you want to update amtm now?
 Continue? [1=Yes e=Exit] 1
/jffs/scripts/amtm: line 2: : Permission denied
Running again gives:
admin@RT-AC86U:/tmp/home/root# amtm
 amtm 3.1.0                by thelonelycoder
    The Asuswrt-Merlin Terminal Menu
 4  open     YazFi                     v3.2.3
 dc manage   Disk check script   dcl show log
 sw manage   Swap file /mnt/swap 1.5G
 i  show     all available scripts or tools
 u  check    for script updates
    amtm options
 e  exit      t  theme   r  remove   a  about
 - Module diversion.mod downloaded
 - Module FreshJR_QOS.mod downloaded
 - Module YazFi.mod downloaded
 - Module scribe.mod downloaded
 - Module connmon.mod downloaded
 - Module ntpmerlin.mod downloaded
 - Module scmerlin.mod downloaded
 - Module spdmerlin.mod downloaded
 - Module uiDivStats.mod downloaded
 - Module uiScribe.mod downloaded
 - Module entware.mod downloaded
 - Module disk-check.mod downloaded
 - Disk check script updated to v2.7
 Enter option
I assume all OK?
I'm working on it.
I pulled the v3.1.0 version from the server until I found the reason for this permission denied error.
Should be working now ;)
I was able to successfully update to 3.1.0 about 20 mins ago and now when I enter amtm into terminal it displays:
-sh: amtm: not found
When I start it manually in /jffs/scripts and enter u it offers me to "update" to 3.0 (probably because you pulled 3.1). Is it safe to downgrade or should I just leave it like it is for now?
If amtm is embedded in the firmware, does that mean you will be unable to release bug fixes independent of firmware releases (which are few and far between)?
I think I'd prefer the option to continue running the standalone amtm, so prompt updates are possible.
As stated in original announcement, both amtm versions will get the updates at the same time and they're not firmware dependant.
  • Like
Reactions: a5m
Fixed, amtm v3.1.0 is again available to install. Sorry for the inconvenience. For those that have it already installed, just run the regular u update.
That's why there are two versions now. They act the same but are different how they internally work. And of course, both versions receive updates.
Verify the following line in /jffs/configs/profile.add
alias amtm='/jffs/scripts/amtm' # added by amtm
That's the reason to log out of the SSH session. Those that don't have Entware installed get that added. But it requires a log out first to kick in.
Thanks for the quick replies!
I logged out and nothing changed after logging back in.
Should I create the file profile.add manually in configs then?
Edit: since the file is not present in configs
So you have Entware installed then. Try typing amt only and press the TAB key, it should complete it to amtm.
Minor Update applied without error.
Many Thanks!
It is really weird it just does not want to find amtm now, whereas before it worked flawlessly.
Is there any file/folder in /opt where I could check wether the reference for amtm exists?
