Thank you, I have done that and will try logging back in later to confirm it works, I think when I did that on the previous build I didn't log out!@GoNz0 type 'r' while in the amtm menu and then exit your ssh session. This will reset amtm. Read what changes it does and take appropriate actions, if you need to.
Log back in and typing amtm will come up (be a little patient at this step, it is re-installing).
Don't forget to re-enable the disk checker (and the reboot scheduler afterward, if needed).![]()
