amtm amtm update error
figorr
I have just seen this error trying to update the scripts through amtm. "raw.githubusercontent.com unreachable"
I have updated scmerlin and other scripts, a couple of days ago, without any problems. But today ... It was not possible to check or update any of these scripts.
Is someone having a similar issue?
I have check Skynet and Diversion and it seems they are not blocking "raw.githubusercontent.com". This domain is already in the Skynet whitelist and Diversion said (when I tried to included in the Whitelist) that this domain is not inside the blocking list.
Ok. It is weird. I have tried "Terminal" though macOS, and "Termius" in the iPad. Both ... same result. Tonight I will try to reset the router in order to see if it helps.
No luck. I restarted the router, disabled Diversion & Skynet and I am still getting the same error for the scripts located at GitHub.
Doing ping raw.githubusercontent.com
I am getting ...
--- raw.githubusercontent.com ping statistics ---
5 packets transmitted, 0 packets received, 100.0% packet loss
All the packets are lost. I don't know what it is blocking this domain.
The address is pinging for the raw.githubusercontent.com is 185.199.109.133
PING raw.githubusercontent.com (185.199.109.133): 56 data bytes
76 bytes from 241.red-81-46-7.customer.static.ccgg.telefonica.net (81.46.7.241): Time to live exceeded
Vr HL TOS Len ID Flg off TTL Pro cks Src Dst
4 5 00 5400 abb3 0 0000 01 01 23a7 192.168.2.90 185.199.109.133
This is what I am getting by pinging from the router
ASUSWRT-Merlin RT-AX88U 386.3_0 Fri Jul 23 17:53:02 UTC 2021
admin@JUANDOASUS:/tmp/home/root# ping raw.githubusercontent.com
^C
21 packets transmitted, 0 packets received, 100% packet loss
I think there is something wrong with the routing by your ISP. I think this is something only your ISP can fix.
Just one thing I have just tested.
I connected the PC to the VPN (TorGuard). Using a United States server. And now I can ping raw.githubusercontent.com without major problems.
Juando@MacBook-Pro-de-Juando ~ % ping raw.githubusercontent.com
PING raw.githubusercontent.com (185.199.111.133): 56 data bytes
64 bytes from 185.199.111.133: icmp_seq=0 ttl=59 time=108.155 ms
64 bytes from 185.199.111.133: icmp_seq=1 ttl=59 time=107.079 ms
64 bytes from 185.199.111.133: icmp_seq=2 ttl=59 time=107.135 ms
64 bytes from 185.199.111.133: icmp_seq=3 ttl=59 time=113.604 ms
64 bytes from 185.199.111.133: icmp_seq=4 ttl=59 time=106.116 ms
64 bytes from 185.199.111.133: icmp_seq=5 ttl=59 time=152.082 ms
^C
6 packets transmitted, 6 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 106.116/115.695/152.082/16.455 ms
So it seems the ISP provider is blocking raw.githubusercontent.com
My ISP provider is Movistar, from Spain.
I have seen another thing ...
When I ping raw.githubusercontent.com from home (Movistar ISP) it is resolving IP 185.199.109.133.
But at work ... If I ping raw.githubusercontent.com ... (at work we have a different ISP provider, I thing it is JAZZTEL) it is resolving the IP 185.199.110.133.
Is there any way I can force (by using dnsmasq.conf) to resolve raw.githubusercontent.com as IP 185.199.110.133?
Could be something like this?
address=/raw.githubusercontent.com/185.199.110.133
Is this the correct way? I don't know if this could be a temporary solution?
Should I restart the router after applying this change to dnsmasq.conf or it would be enough if I restart dnsmasq using scMerlin?
raw.githubusercontent.com resolves to four different IP addresses. So which one is used will be random.
# nslookup raw.githubusercontent.com
Server:    127.0.0.1
Address 1: 127.0.0.1 localhost.localdomain
Address 1: 185.199.108.133 cdn-185-199-108-133.github.com
Address 2: 185.199.109.133 cdn-185-199-109-133.github.com
Address 3: 185.199.110.133 cdn-185-199-110-133.github.com
Address 4: 185.199.111.133 cdn-185-199-111-133.github.com
Server:    127.0.0.1
Address 1: 185.199.111.133 cdn-185-199-111-133.github.com
Address 2: 185.199.110.133 cdn-185-199-110-133.github.com
Address 3: 185.199.109.133 cdn-185-199-109-133.github.com
Address 4: 185.199.108.133 cdn-185-199-108-133.github.com
Server:    127.0.0.1
Address 2: 185.199.111.133 cdn-185-199-111-133.github.com
Address 4: 185.199.109.133 cdn-185-199-109-133.github.com
But if you find one address that always works the easiest option is to add it to the hosts file:
# echo "185.199.110.133 raw.githubusercontent.com" >> /jffs/configs/hosts.add
# service restart_dnsmasq
Done.
Server:    127.0.0.1
Address 1: 185.199.110.133 raw.githubusercontent.com
