Apply button doesn't work
mooksmd
I am trying to enable static IP addresses . After I enable "manual" address and click on "apply" nothing happens.
If I leave the page and come back to it, the changes are gone. In other words clicking "apply " doesn't save
any changes.
Tried rebooting, other browsers... still no joy.
Any suggestions?
tnx
Mike
Here's a screenshot . Yes, its a RT-AX88U Pro.Didn't know that there would be a difference. tnx Mike
Can you try setting up a single address to add to the list and then post a screenshot just before you hit the Apply button.
Hmm... sounds like a bug, or possibly a wider hardware issue.
If you make changes to other router pages are those changes applied successfully?
Side note: People generally don't want to specify DNS servers on the LAN page. Most people prefer to leave those blank so that they get the advantage of local DNS caching and the ability to resolve local names.
tnx for the DNS tip.
The problem seems to have mysteriously solved itself. When trying to save other pages, the APPLY button worked, so I tried it on the reserved IP list and it worked. Go figure.
Tnx for the patience and help. Mike
