Tutorial Aria2 - WebUI on AsusWRT-Merlin
I'm having trouble configuring and accessing webui-aria2
I followed these steps
I need knowledge of entware packages. The entware repository needs to be installed. Following the steps of the first post, there is no error.
I am aware of entware packages, they are installed, functional by the AriaNG extension, I just can't access the webUI in the browser!
It is necessary to check if the lighttpd server is active and the aria2-webui zip file has been unzipped in the public web folder, as instructed in the first post.
webui-aria2 > WebUI does not work
wget -c -O /opt/tmp/webui- aria2.zip https://github.com/ziahamza/webuiaria2/archive/master.zip --no-check-certificate
unzip /opt/tmp/webui-aria2.zip -d /opt/tmp/
rm /opt/tmp/webui-aria2.zip
mv /opt/tmp/webui-aria2-master /opt/share/www/aria2
AriaNg 6 > Normal functioning by the browser extension
wget -c -O /opt/tmp/ariang.zip https://github.com/mayswind/AriaNg/archive/master.zip --no-check-certificate
unzip /opt/tmp/ariang.zip -d /opt/tmp/
rm /opt/tmp/ariang.zip
mv /opt/tmp/AriaNg-master /opt/share/www/ariang
Remove
rm -R /opt/share/www/aria2
Insert direct download
curl -SL https://github.com/rgnldo/knot-resolver-suricata/raw/master/aria2_ui.tar.gz | tar -zxC /opt/share/www
restarting aria2 and lighttpd
Strange, your web server. With the interruption it remains active.
Configuring the sertanejo music style. :)
I liked ariaNG too. The important thing is that aria2 works.
@rgnldo
I suspect torrent downloading in aria2 is affected by number of pieces, can we amend this value? And any light on this piece concept, i normally see 8 to 16 pieces but here in aria2 , it's showing a value in thousands, like 4445 pieces etc, is it normal and what's the implication??
Yes, it is possible. You should stop Aria2, edit and start Aria2 again. Pieces help with speed. Torrents rely on seeds for speed. Do the values test and let us know.
@Sidiclei and others, let them know if they have resolved it as soon as they use help posts.
Where to change this value? Aria2.conf doesn't seem to have this value or I've overlooked it??? :rolleyes:
@rgnldo
My findings for slow torrent downloading can be any of following reasons
1. Dht.dat path in aria2.conf is not suitable for all, default is /opt/var/aria2/dht.dat whereas in my case its /tmp/mnt/HDD/entware/var/aria2/dht.dat
2. Itself dht doesn't feel optimized, maybe my theory is wrong
3. Aria2 makes alot of pieces
4. Does we need certain port forwardings in firewall-start?? If any please specify , so proper announce is possible
I think we need well optimized aria2.conf file overall and proper port openings to get good results
I've seen your other projects and i believe you can optimized this project pretty easily and mark it as best singlessingle for torrents+ftp+http/https downloads etc
Thanks & best of luck
Standard file is:
dht-file-path=/opt/var/aria2/dht.dat
max-concurrent-downloads=2
max-connection-per-server=10
min-split-size=50M
split=8
Do it at your own risk. Memory and processing will increase.
iptables -A INPUT -p tcp --destination-port 6881:6999 -j ACCEPT
iptables -A OUTPUT -p tcp --source-port 6881:6999 -j ACCEPT
Always happy and appreciative of your knowledge and contributions @rgnldo. Even though many of us always try to tweak our routers just a bit more, I might just wait this one out for the moment.
My router and aria2 is working just fine at the moment with great speeds.
@rgnldo
I managed to make it work, both through webui-aria2 as well as through Aria2App!
How can I do for port forwarding, with the intention of remote access? firewall? open pots? ddns?
@rgnldo
I would advice against port forwarding in order to create remote access. Create a VPN server for more security. It will give you secure access to your home network.
Use yorgis guide to do so: https://www.snbforums.com/threads/h...with-asus-routers-380-68-updated-08-24.33638/
After you have set it up, Export OpenVPN configuration file and import it to your OpenVPN application in your phone or computer in order to VPN into your local network and/or route your internet traffic through your home router from remote.
You can setup DDNS under WAN/DDNS in the WebUI. There are many options. I use NO-IP since it is free, however needs to be updated every 30 days.
You create the host name at their website and can afterwards use the login credentials from NO-IP in the router WEB-UI.
If you have a dynamic IP-adress (which might change frequently), I would set WAN IP and hostname verification to Yes. The router will then regularly check that the hostname matches the current IP, and if not it will update it.
Once your DDNS is working correctly, you will see if on the main page of the router WebUI.
