Assistance with Large Wifi Network over multiple Buildings Ubiquiti
This is also good quality equipment with similar capabilities and very similar control panel. The only potential issue - their wired routers have less features compared to newer generation UCGs from Ubiquiti. Take a closer look at what the installer is offering. Otherwise may come cheaper for comparable performance.
I believe they are putting in some super router, not sure of the model yet. Also further to previous, we are now discussing putting fibre (SFP) between switches instead of copper for reasons of future proofing, earthing safety (as mentioned earlier) and speed. Exciting stuff.
Keep us updated on the progress. We can use this thread for an example of what has to be done for larger coverage area deployment.
Will do, will probably take the best part of a year to all be up and running however :)
