Asus 68u repeater mode
Router is getting 50% signal since repeater is setup in basement, Should I assign channels for Router currently internet provider has it set to auto. If so which channels for 2.4ghz and 5ghz should I set it to? Router is using 1 said for both ghz frequencies so I have repeater set to use 1 ssid (not same as router) for both frequency .
I manually assigned IP address to iPhone and switched to Merlin firmware. Will update with results
