I recently upgraded to 200 mb/s connection. I have been using the stock firmware.
In the last few months, the wired speed has gone down to less than the half of cable broadband speed. I also replaced the stock with Asuswrt Merlin. This has no impact at all. The ethernet speed is still 90-95 mb/s, while the upgraded speed is 200 mb/s. I pay a business grade broadband and phone bundle.
The superhub supplied by the ISP is used as a modem. I am not sure what the problem is. In the past, this router used to give me a full speed, which was the pre-upgrade speed of 152 mb/s.
I am thinking if I should chuck this and perhaps get a Mikrotik or Edgeswitch lite or ER PoE.
I would appreciate comments and recommendations to fix the asus problem.
Thanks,
Sundar
Thanks,
Sundar
