thewickedpickett
Hello
I run an Aimesh system with AX88u as primary and 3 AX82Us as nodes. All nodes use ethernet backhaul. 2 are connected to the main router and one is daisy chained off one of the nodes LAN ports.
My issue is that all my devices show as connected to the main 88U router. Some time ago I used to see devices jumping around from node to node etc but not any more. I could also see wired devices listed under the correct node but not now.
The interesting thing is that speed tests and the like strongly suggest wireless devices are connecting to the nodes. Why do they all appear under the main 88U?
I contacted ASUS a few times but they were unhelpful. Any ideas. I have searched around but not found this particular issue.
