guruabyss
AiMesh Router: RT-AX89X (Firmware: 3.0.0.4.386_47468-g73fe1fe) (Product Link: https://a.co/d/6GnccP6)
AiMesh Node: RP-AX56 (Firmware: 3.0.0.4.386_42862-ga9f43cc) (Product Link: https://a.co/d/1fL9diz)
Issue: Bought the RP-AX56 to expend my network, used WPS to quick connect to the node/ router. Worked great for two months. Today my routed needed to be rebooted. Noticed my node light blinking blue like if I actived the WPS button on the node but it wasn't connecting to the router, so I tapped the WPS button on my router and waited 5 min, Node didn't connect. Unplugged/ plugged back in the Node. Went from white light to blinking blue. Tapped the WPS button on the router, node light turns green. Hazzah. On or about 20 min later node disconnects and blinks blue again like it want's to connect to the router. Tap WPS button on Router. Node doesn't connect. Only time the node will connect back to the Router is if I unplugg and plug back in the Node. Again it only lasts for 20-30min before it just disconnects.
Problem solving: I tried to factory reset the Node, no luck there. Tried a different power cable, that wasn't the issue. I have the late firmware for both the Node and the Router. Googled terms "ASUS RP-AX56 keeps disconnecting" and "ASUS AiMesh node keeps disconnecting" no such luck on this particular use case. Any clue what it could be?
