tiddlywink
New firmware: Current Version : 3.0.0.6.102_44416
Logs have been empty but now:
Despite less than 3% CPU usage, the gateway appears to be trying to thermally throttle and failing. Anyone know how to check temps via SSH?
Dec 31 18:00:23 avahi-daemon[3322]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Dec 31 18:00:24 avahi-daemon[3322]: Alias name "ExpertWiFi_EBG15" successfully established.
Dec 31 18:00:27 UAM server: daemon is started
Dec 31 18:00:27 dbus: daemon is started
Dec 31 18:00:27 ERP: The model isn't under support list!
Dec 31 18:00:29 rc_service: cfg_server 4166:notify_rc update_nbr
Dec 31 18:00:29 rc_service: waitting "restart_firewall" via ...
Dec 31 18:00:30 modprobe: module ledtrig-usbdev not found in modules.dep
Dec 31 18:00:30 modprobe: module leds-usb not found in modules.dep
Dec 31 18:00:30 kernel: SCSI subsystem initialized
Dec 31 18:00:30 modprobe: module scsi_wait_scan not found in modules.dep
Dec 31 18:00:30 modprobe: module mbcache not found in modules.dep
Dec 31 18:00:30 modprobe: module jbd not found in modules.dep
Dec 31 18:00:30 modprobe: module ext3 not found in modules.dep
Dec 31 18:00:30 modprobe: module ext4 not found in modules.dep
Dec 31 18:00:30 modprobe: module ext2 not found in modules.dep
Dec 31 18:00:30 kernel: tfat: loading out-of-tree module taints kernel.
Dec 31 18:00:30 Mastiff: init
Dec 31 18:00:31 modprobe: module btusbdrv not found in modules.dep
Dec 31 18:00:18 kernel: ++++ Powering up USB blocks
Dec 31 18:00:18 kernel: hub 1-0:1.0: config failed, hub doesn't have any ports! (err -19)
Dec 31 18:00:18 kernel: broadcomThermalDrv brcm-therm: init (CPU count 4 2 4 2)
Dec 31 18:00:18 kernel: brcm_otp_init entry
Dec 31 18:00:18 kernel: thermal cooling_device1: take CPU#2 online
Dec 31 18:00:18 kernel: psci: failed to boot CPU2 (-22)
Dec 31 18:00:18 kernel: CPU2: failed to boot: -22
Dec 31 18:00:18 kernel: thermal cooling_device1: take CPU#3 online
Dec 31 18:00:18 kernel: psci: failed to boot CPU3 (-22)
Dec 31 18:00:18 kernel: CPU3: failed to boot: -22
