Release Asus GT-AXE 11000 New firmware Version 3.0.0.4.386.45850 9/30/2021
cc666
Just released:
2021/09/29 80.35 MBytes
ASUS GT-AXE11000 Firmware version 3.0.0.4.386.45850
1. Extend the maximum limit of manually assigned IP quantity
2. Improve system stability and fix GUI issue
3. This version includes several vulnerability patches.
BusyBox
- CVE-2016-2148
- CVE-2016-6301
- CVE-2018- 1000517
cURL
- CVE-2020-8169
- CVE-2019-5481
- CVE-2019-5482
- CVE-2018-1000120
- CVE-2018- 1000300
- CVE-2018-16839
Lighttpd
- CVE-2018-19052
Linux
- CVE-2020-14305
- CVE-2020-25643
- CVE-2019-19052
lldpd
- CVE-2020-27827
Avahi
- CVE-2017-6519
hostapd
- CVE-2021-30004
- CVE-2019-16275
OpenVPN
- CVE-2020-11810
- CVE-2020-15078
wpa
- CVE-2021-30004
- CVE-2021-27803
- CVE-2019-11555
- CVE-2019-9499
- CVE-2019-9498
- CVE-2019-9497
- CVE-2019-9496
- CVE-2019-9495
- CVE-2019-9494
- CVE-2017-13086
- CVE-2017-13084
- CVE-2017-13082
- CVE-2016-4476
- CVE-2015-8041
Fixed DoS vulnerability from spoofed sae authentication frame. Thanks to Efstratios Chatzoglou, University of the Aegean, Georgios Kambourakis, European Commission at the European Joint Research Centre, and Constantinos Kolias, University of Idaho.
Please unzip the firmware file first then check the MD5 code.
MD5: 155a57669cd7af1c514f64004846480f
CC
Anyone with any comments on this new release?
For me so far so good. I have a mesh system with a GT-AC5300 hard wired. All working perfectly.
CC
CC
Is this still running well for you? I just upgraded today. I was having a bit of an issue with 43986. I would find myself running into occasional WAN drops because of what I assumed was a memory leak. I hope whatever was causing my problem has since been resolved.
Out of curiosity, what steps did you use to set up the AC5300 in a wired AImesh configuration? I assume it is something like:
1. Plug in a factory reset AC5300 near the AXE11000
2. Configure AC5300 through quick set up
3. Wire any LAN connection on the AC5300 to a LAN connection on the AXE11000????
No. That is wrong.
Perform a full reset to factory defaults using the WPS Button method appropriate for your router.
[Wireless] ASUS router Hard Factory Reset | Official Support | ASUS Global
Do not touch the router after the router reboots.
Go to the main router's GUI and click 'Add AiMesh node'.
After the node has been successfully added, I suggest waiting at least 15 minutes for the node to be fully configured and allow it to settle down.
Now, unplug the node and physically move it to the location you want to use it in.
No. That is wrong.
This is helpful. A couple of clarifying questions if you don’t mind:
1. Is the full factory reset of the mesh node or the primary node?
2. After the mesh node is configured, do I connect the WAN port of the mesh node to a switch port on the primary node?
thanks
1. Usually, just the AiMesh node needs a full reset. But if issues persist, doing a full network reset is the next step I would do.
2. Yes.
No. That is wrong.
This is how I did it
CC
