ASUS headache - Help!
Thanks. I don't think the 86U can be resetting properly. I don't see how any attached devices (like tablets, phones, PS4, Alexa, printer, network switch, Sonos etc.) can "remember" previously attached devices and feed those back to the router as L&LD suggests could be happening. To my understanding, a full reset is just that, with a complete wipe of everything, and the suggestion that there must be a hardware issue makes more sense to me. Not sure what to do about that though, given that it is a £200+ router and is now over a year old.
I am up and running at the moment with the 86U as the main router, I just can't use parental control settings and have to keep re-entering the printer IP. I will see (as someone else suggested) if I can enter the IP into the printer so that it remembers it if the router forgets it.
Is there any other way to hard reset that might be more effective (like the reset button) or does it just do the same thing?
Anyone have an opinion on whether Merlin firmware might help? or how to get Asus to tell me if they think it is a hardware issue?
thanks again to all
I am quite sure its not a hw problem.
What does it exactly remember after a reset?
Clients got their DHCP lease, so they may reuse it after a reset again (but not sure about this).
Soft (with initialize) or hard (button) reset should work the same.
But this router has 2 firmwares (one in reserve if working one wont boot) and there are sometimes going on strange things.
Thats why L&LD recommends his nuclear reset (with uploading firmware twice and reset after each step).
After reset use a different SSID for testing, does it still remember anything?
Did you set fix IP in DHCP reservation list for the printer, then it will get this predefined one and keep it.
Well I have followed the initial instructions from L&LD as best I can. I flashed with an old firmware that I had on the PC then flashed again with the latest firmware from the website. Then reset via the GUI (with the initialize box checked) and hard re-boot (unplugged for a few minutes). It came back up with the configuration wizard and I picked a new radio name. It then told me that I had picked a new name, so existing clients would need to re-connect. If I go to the DCHP settings, I can still see under the "offline clients" section all of the previous devices that have connected in the past.
Clearly the router is not actually returning to factory settings and forgetting everything. Does anyone know how to completely reset it? I think that either there is a hardware problem (less likely) or something in it's memory has got corrupted and I seem to be unable to reset it.
Unless I can somehow clear its memory I am not really sure how I can stop it suddenly doing unpredictable things. Any further suggestions as to how I might achieve this will be gratefully received - and thanks for all of the comments so far.
Log into the router's web interface and go to Administration - System and set Enable SSH to LAN only.
OK. I set port 1025 - not sure if that is important or not
Personally I would have left it at the default. The important part is that it should be "LAN only".
Go to the Windows command prompt and connect to the router with:
ssh admin@192.168.1.1 -p 1025
Change "admin" to whatever your router user name is. Change 192.168.1.1 to your router's IP address.
Then enter the commands above and the router should reboot itself twice.
Do I need to put that other code in the "authorised keys" box? or should that stay blank?
I can't remember what it says exactly. Can you just press return to continue?
EDIT: I think you're talking about the router's SSH config. Just leave that box empty.
After you enabled SSH on the router did you press the Apply button? Try rebooting the router just to make sure it's enabled properly.
Are you sure you're using the correct port number?
Re-boot has let me in. it has my router id then:/tmp/home/root#
