chrisr4g
Hi guys,
I`m sorry if this was posted elsewhere but right now i`m on the edge of returning my new router ( GT-AX11000 ).
I have 2 issues with it :
- Can`t connect to the UI ( neither https protocol / ip / ip with https port / etc. ) -> Also tried a reboot
*router.asus.com
*https://router.asus.com
*https://router.asus.com:8443
*and the same combinations for the lan ip ( from ipconfig )
The problem here started when for some reason I tried to enable https from the Asus Router app on my phone and since then it never connected again both on the app and on the wire connected laptop.
- Wireless connection drops with no pattern detected ( but since i cannot connect to the UI to see the logs I may be wrong about this ).
I checked the forum and googled it for about a week now but nothing seemed to work for me, the only thing left to do is a hard reset which i`ve been avoinding this whole time.
From what i`ve learned i have the latest firmware (384), the modem is correctly set into bridge mode and the router with the proper credentials from the ISP.
Is there anything else I can try to solve the UI problem? And for the drops should I disable the smart connection rules ( disable the automatic switch between bands )?
Also, I have a Asus Lyra Voice AC meshed onto my GT-AX11000 which seems to work fine but i read that the for some people Lyra Voice crashed their network somehow. What`s your take on this?
Thank you in advance
*router.asus.com
