ASUS RT-AC3200 Firmware - Official Releases
If you read up a couple posts you will see that I was concerned about jumping a couple versions. That is what I was referring to when I say 'everything seems to be ok'. To answer your questions I am on the latest now, 3.0.0.4.378_9459. 'No drop', not sure what you mean. I don't see any devices dropping the Wifi if thats what you mean. 'Smart thing'? If you mean Smart Connect I don't use it as I haven't yet learned how to set up the rules properly.
Can u try it and use smart settings to default and see if u get dropped connection? Thx
OK I've switched it on, and left everything at the defaults. All devices disconnected and I had to re-connect them all, no big deal. It's only been a few minutes but so far no problems. Devices are streaming, surfing and no disconnects.
I'll watch things and see how it goes...
U use smart settings right? So how the drop? Bo connection dropped? And u use mac? Are there drops thx
Not sure what you mean by smart settings? I currently have all the Smart Connect at the defaults. So far no drops. 'Bo' connection? I have Mac's and PC's on my network.
Edit: If by 'smart settings' you mean the Smart Connect Rules, those are at the defaults.
Yea. That thing. Anyway thx. U use stock fw?
So. Any new news? :)
No, which is good I guess. I have not seen any dropped connections. Network speeds are normal. VPN connections are working normally.
My network is comprised of iMacs, PC's, iPhones, iPads, Playstation, and a Synology server. The Synology server is the only device hard wired to the router.
Edit: Now that the work week is here the network will get used a bit differently. So I'll watch it and see what happens.
Thx and. If i can know. Did u set the radio band manual settings? Like enable thing on radio like 5ghz-1? Thx so much for ur help
Not understanding your question. Attached is a pic of my settings (which is default settings).
So no more hourly disconnects with key rotation set at 3600 sec on stock FW ? Or have the found a fix ?
Hey guys. Anyway is there like someway that i can check if the router is real? Like no counterfeit? If there any counterfeit item. How to identify it? Thz
First stop; where did you buy it from?
