ASUS RT-AC3200 Firmware - Official Releases
Where did I miss key rotation setting in the past here?! What is the default, and why 3600?
Initially people reported a bug that dropped certain types of WiFi clients every hour on the hour. That's 3600 seconds, the default setting. The workaround was to set it to 0, thus turning off that feature, trading off security for reliability. The default seems to work fine in recent firmware releases.
Didn't have a disconnect so far, but has been on only for a couple of hours.
Smart connect is disabled and key rotation is at the default 3600.
So far it is running very good and stable. All wired and wireless clients seem to like this router much better than the RT-AC87 it replaced. Not a single wireless drop.
you would have seen the drop in the first hour if there were still a key rotation bug , have not had that problem for long time , it was fixed many FW builds ago . AC3200 is super stable these days
There's an update available dated june 1.
Select Win 8/8.1 for it to show. http://www.asus.com/Networking/RTAC3200/HelpDesk_Download/
c/v:
ASUS RT-AC3200 Firmware version 3.0.0.4.378.9529
Releases note:
ASUS has been dedicated to cooperate with third party developers to come up with more innovative features.
To comply with regulatory amendments, we have modified firmware verification rule to ensure better firmware quality.
This version is not compatible with all previously released ASUS firmware and uncertified third party firmware.
Security Fixed
- Fixed Samba Badlock CVE-2016-2110 (Man in the middle attacks possible with NTLMSSP)
- Fixed Samba Badlock CVE-2016-2111 (NETLOGON Spoofing Vulnerability)
- ASUS firmware did not enable Samba LDAP, and not affected by CVE-2016-2112 (LDAP client and server don't enforce integrity) issue.
- The Samba version in ASUS firmware was not affected by
CVE-2016-2118 (SAMR and LSA man in the middle attacks possible)
CVE-2015-5370 (Multiple errors in DCE-RPC code)
- Fixed command injection issue. Thanks for Chris' contribution.
- Fixed XSS issue. Thanks for Chris' contribution.
Bug Fixed
- Fixed Windows Radius server compatibility issues.
- Fixed 5G performance issue when using bandwidth monitor.
- Fixed bandwidth monitor incorrect number problem.
- Fixed setup wizard redirect issue when router automatically changed LAN IP in IP conflict case.
- Modified setup wizard process when router detected DHCP and PPPoE at the same time.
- Fixed bandwidth limiter bug when there are multiple clients in rule list.
- Fixed NTP automatically sync issue when router rebooted
- Fixed Safari slow response issue.
- Enhance AiCloud dynamic stream port mechanism (please also keep AiCloud app up to date)
- Fixed AiCloud share link related issues.
edit: updated without any issues although the router now forward my local IP to http://router.asus.com/index.asp for login (I don't really like that).
There seems to be a typo in their changelog. This is really 3.0.0.4.380_3479, which is indeed a new release.
ASUS RT-AC3200 Firmware version 3.0.0.4.380.4180
Security related
- Updated OpenSSL library to 1.0.2j to fix security issues.
- Updated Dropbear SSH to 2016.74 to fixe security issues.
- Fixed a security vulnerability regarding XSS.
- Fixed a security vulnerability regarding CSRF.
- Added protection for Brute-force attack.
Bug fixed
- Fixed out of memory issue when using guest network.
- Fixed Chrome, Edge and IE compatibility issues.
- Fixed quick internet setting wizard compatibility issues.
- Fixed NAT issue caused by UPnP media server.
- Fixed dual wan issues in PPPoE or PPTP or L2TP + DHCP environment.
- Fixed AiCloud related issues.
- Fixed AP mode interoperability issues
Modified
- Updated NAT Acceleration setting help message.
- Supported Google DDNS. .
- Enabled smart sync under AP/Media Bridge.
- Supported new 3G/LTE USB dongle Docomo L-03D.
MD5: 84dacc23227e34d3e103f4bcc8c32cc4
38.42 MBytes update 2016/12/20
Updating now :)
edit: no issues to report! My devices reconnected just fine. MAC filter, Port forwarding and DHCP settings retained. Still a bit slow browsing some settings but no big deal.
Good luck to you all and merry christmas
Security related
Bug fixed
Modified
Updating now :)
This has thus far made small rule perform much better and balanced between the two 5ghz bands.
Yet my router has experienced crash (refused to connect the web console) two times in the last few days. Appeared to be related to large data traffic volume. Once I was watching netflix, and this morning just now while I'm uploading music to google play.
While the improvement of smart rule is lovely, I can't bear the crash anymore but to restore to last firmware Version 3.0.0.4.380.3479. Albeit I do have large number of device online, from wifi cam to amazon alexa over 50 devices. I just have to set the router to reboot once a day with the previous firmware, but it never crashes.
Version 3.0.0.4.380.7266 2017/02/14
Description ASUS RT-AC3200 Firmware version 3.0.0.4.380.7266
Bug fixed
- Fixed Android phone tethering mode detecting issue in quick internet setup process.
- Fixed PPPoE related issue.
- Fixed client rename issue in network map.
- Fixed network tool issues.
- Fixed wake on lan issues.
Modification
- Added automatic standby mode for CE Ecodesign directive.
MD5: f265b8c9bc7129b6a64b122ed37b52d4
File Size 38.44 MBytes
https://www.asus.com/Networking/RTAC3200/HelpDesk_Download/
Hoping for a working WOL from outside of LAN! :)
edit:
no issues updating!
I applied firmware yesterday and notifced it my internet would drop off after an hour or so. A soft reset would not work. Today, got home same thing. can't connect to discord or get to live.com. However, I could get to google (not using google dns). I proceed to unplug the router and turn off the power switch then plugged it back in. Wait 10 sec then turn on the power switch in the back. Been running for 4 hours no problem. Will report back if the internet drops off. Another thing that happened yesterday, the external IP had changed but I'm not sure if this had anything to do with my problem.
Also what is the entry source target for. Is this for the source IP address?
If you want to setup a port forward that only works for traffic coming from a specific IP address.
2017/06/26
Version 3.0.0.4.380.77432017/06/2638.71 MBytes
ASUS RT-AC3200 Firmware version 3.0.0.4.380.7743
Security fixed
- Fixed CVE-2017-5892 (JSONP Information Disclosure)
- Fixed CVE-2017-7494 (Samba remote code execution vulnerability
- Improved brute-force protection for SSH, Telnet connection.
Bug fixed
- Fixed web history issue.
- Fixed URL filter, keyword filter, network filter time related issue.
Please unzip the firmware file first then check the MD5 code.
MD5: a2fe11ab0237caed72a07a05974c919f
Download Link
