Well, unless I am reading those wrong(ya never know with me lol) those numbers look fine and are better than what that review showed.
Okey, fine with me. I have only played with this for about 10 years.
Maby I have learnt something.
octopus![]()
http://www.dd-wrt.com/phpBB2/viewtopic.php?t=86437&start=857Asus RT-AC66U running 3.0.0.4.164 stock firmware
Telnet Session with 192.168.5.1:
admin@RT-AC66U:/tmp/home/root# nvram show|grep size:
size: 30104 bytes (35432 left)
admin@RT-AC66U:/tmp/home/root# dmesg|grep -E "\-0x0|MTD|NAND| ST "
Found an ST compatible serial flash with 32 64KB blocks; total size 2MB
Creating 2 MTD partitions on "sflash":
0x00000000-0x00040000 : "pmon"
0x001f0000-0x00200000 : "nvram"
Found a Samsung NAND flash with 2048B pages or 128KB blocks; total size 128MB
Creating 2 MTD partitions on "nflash":
0x00000000-0x02000000 : "linux"
0x001313e8-0x02000000 : "rootfs"
NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit)
Creating 2 MTD partitions on "brcmnand":
0x00000000-0x02000000 : "trx"
0x02000000-0x07f00000 : "brcmnand"
admin@RT-AC66U:/tmp/home/root# cat /proc/mtd
dev: size erasesize name
mtd0: 00040000 00010000 "pmon"
mtd1: 00010000 00010000 "nvram"
mtd2: 02000000 00020000 "linux"
mtd3: 01ecec18 00020000 "rootfs"
mtd4: 02000000 00020000 "trx"
mtd5: 05f00000 00020000 "brcmnand"
admin@RT-AC66U:/tmp/home/root# dmesg|grep -E "Broadcom BCM"
eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.30.39.29 (r338244)
eth1: Broadcom BCM4331 802.11 Wireless Controller 6.30.39.29 (r338244)
eth2: Broadcom BCM4360 802.11 Wireless Controller 6.30.39.29 (r338244) <== 802.11ac
admin@RT-AC66U:/tmp/home/root# uname -a
Linux RT-AC66U 2.6.22.19 #1 Mon Jul 23 18:27:45 CST 2012 mips GNU/Linux
Just as a heads-up: I just received a new RT-AC66U today in the mailThat means I'll be able to work on giving it official support in Asuswrt-merlin in the near future.
I'll agree, the N66U is probably the better device right now, but I expect the bugs to be ironed out on the AC66U and going forward, for me, the AC66U makes the most sense, since I tend to stick with my router for a while(coming from a now 3 yr old Netgear WNDR3700).
Yeah, keep in mind this is Draft ac though. Once the standard is released, you may want something else.
Just a note on the TX settings, I was glancing at the reviews at Newegg.com on this router and several people were complaining about the lack of the TX setting(which is why several people gave it poor reviews). Jeremy from Asus commented on a few of them that they were aware of it missing and were working on correcting it in the next firmware update.
Hopefully we will see it return shortly.
However, I'm waiting to see if we get the TX power adjust setting back. I only need to cover 2 adjacent rooms and would love to be able to turn the power *down* below the default![]()
Yeah, but what is the real impact of draft AC vs final AC?
People will have to be patient I guess. The AC66U is a much more different beast from the N66U than I expected. For starter, there's not one, but two flash storage devices. And no JFFS partition.
Also regarding performance: build 162 has a newer driver than the version that they shipped with. So any performance review needs to ensure to mention which firmware they were running (the CNet review doesn't). Otherwise, take any benchmark with a gain of salt.
Hello RMerlin,
I received my AC66U today and it came with firmware version 3.0.0.4.140
Thank you and appreciate your offer to support custom builds for AC66U.
In build 140, via the control panel, firewall is only available in router mode and not in AP mode. I would like to have the firewall in AP mode too.
A humble request, can you enable the firewall in AP mode in your next custom build please?
With kind regards,
AP mode is a whole different beast. Unfortunately I don't have enough time to develop and test all available modes, so my work will always be focused on router mode, sorry. Time is a limited resource and I'm one guy trying to support two different devices on his spare time (plus partial support for a third one).
Beside, the firewall works in relation to a WAN connection, so I don't see its relevance regarding AP mode, where you have no WAN interface.
Welcome To SNBForums
