TimothyM96
Wish it was out today. Doing some work while the network is low since there have been some issues with the AC68U dropping connections, and needed OpenVPN support with the CA support.
Thank you! My 2.4GHz performance is awful. The max speed reported by inSSIDer is 216 Mbps. I actually have to use the 5GHz band for web surfing. As a matter of fact, I was going to go back to my venerable RT-AC66U today until you guys could figure this out. I guess I will wait a couple of more days. I actually got out my AC66U, hooked it up to my laptop, brought up the GUI and went through the settings on my AC68U one-by-one using my desktop making sure they were all an exact match.
Why do this to us? It just doesn't make any sense to release it on the website but not uploading it to its download location. Really disappointing ASUS
Great!
Can anyone please confirm if OpenVPN client is working now? (waiting for AC56U version of this FW)
openvpn work great with my provider, i successfully uploaded config opvn and ca cert.
What provider are you using? I can't get it to work on HMA nor IPVanish yet.
I haven't been able to get OpenVPN to work with iVPN. I copied and pasted all the CA information, key, etc and uploaded the .ovpn. Says it connects, but I check my IP and it doesn't.
now FW still has problem to choose 20/40 MHz bandwidth. So I guess it would be a hardware problem??
Updated to .306 and upgraded mem clock speed to 666 with the new utility. As always with this router, I have no issues with .306 firmware, or previous versions. Performance, range, and reliability are the best I have ever experienced in a router.
I only use port forwarding (with HW acceleration enabled), QoS, 2.4ghz and 5ghz wireless and one LAN cable port.
I suspect the AC68U issues reported by some people are related to setup issues or perhaps due to a feature which I do not have a need to use. Maybe VPN, IPv6, USB or AIcloud bloatware for example.
I think most issues are:
1. 2.4G strength problem( some ppl said N66u had better coverage at 2.4G than AC68U). I notice I have this problem too, I have no coverage(2.4 and 5G) when I am working in my car garage, but I did have coverage when I was using N56u.
2. VPN setup problem.
3. some routers freeze when torrenting.
4. 20/40 bandwidth can not be setup under 2.4G
Welcome To SNBForums
