It seems to be a time thing. Am in the middle of diagnosing, I have a mix of Win 11 and Linux PCs and I couldn't remote into the Win 11 from Linux suddenly or ping. So tried a ping from another Linux machine on the WLAN and again no ping. Rebooted didnt fix. But the router could ping the machine from the firmware network tools page.@banger So Asus broke the ability to ping with this 386_51722 firmware, that's disappointing, did you perform a hard factory reset before you went to Merlin's 386.14_2 firmware?
@wouterv So it seems the 386_51772 firmware is not at fault, it appears to be a configuration issue for some strange reason but Merlin's 386.14_2 firmware has no such issues for @banger, @wouterv would you be able to test your W10 laptop if it pings ok after unblocking the firewall?Maybe you shall explain more about what you are trying and what fails.
With my W10 laptop wireless behind the RT-AC68U Router and 51772 firmware I can ping the devices on our internal home network (like printer, the Media Bridge, other W11 laptop).
I can not ping my W10 laptop which after a quick check seems by default blocked in the firewall.
I am still running 14_2 but it did the same after a few days. Funny it works for a few days then all of a sudden disappears but I can ping from the network tools on the router with success. This all started because something was blocking RDP on the WIn 11 laptop.
@banger Are you suggesting that WPS Reset via the GUI is broken for 386.14_2 or stock 386_51722 firmware or both?Also while resetting my Mesh Nodes to add, which are on stock, the WPS button to reset the node to factory no longer works had to use the button on the back of the router.
- UPDATED: Merged with GPL 386_52805.
- UPDATED: wget to 1.24.5.
- FIXED: WPS wouldn't start on RT-AC68U (note: starting through
webui was fixed, however starting through button is
still broken for the RT-AC66U_B1, including with
stock firmware).
- REMOVED: Wifi Radar was removed (unsupported by Wifi 7 devices,
and security issues cited by Asus in their own recent
releases).
@banger Those are the release notes for 386.14 from July 2024 not the 386.14_2 release notes from November 2024.No I am suggesting that holding the physical WPS button on the router while powering on used to factory reset the device. This no longer works on stock. This is confirmed in the 14_2 revision notes.
Code:- UPDATED: Merged with GPL 386_52805. - UPDATED: wget to 1.24.5. - FIXED: WPS wouldn't start on RT-AC68U (note: starting through webui was fixed, however starting through button is still broken for the RT-AC66U_B1, including with stock firmware). - REMOVED: Wifi Radar was removed (unsupported by Wifi 7 devices, and security issues cited by Asus in their own recent releases).
386.14_2 (17-Nov-2024)
- UPDATED: OpenVPN to 2.6.12.
- CHANGED: Enabled Netfilter queue support for SDK6/SDK7
devices (patch by HiHat)
- FIXED: Security issues in AiCloud (backports from Asus)
- FIXED: CVE-2024-2511, CVE-2024-4741, CVE-2024-5535 &
Implicit rejection for RSA PKCS#1 in openssl
(backport from Ubuntu by RSDNTWK)
I did and picked ch 13 and 36 which is below radar. Router picked 60 on auto for 5ghz but my Alexas were having trouble so changed to 36 out of radar range. Dont forget I am using 3 AC68 routers in mesh. The printer/scanner is connected (bound) to a node as it performs better that way. Will monitor. Interesting to note after I upgraded the firmware back to 51722 from Merlin I had to reboot (system on AI Mesh page) for everything to work with ping.Similar here, RT-AC68U router on 51722, up 53 days, various wireless clients (W10, W11, iPhone, TV box, RT-AC1900U Media Bridge and a Brother printer).
Ping over the local network is already discussed (no issues here) and the printer stays online.
The issues of Banger may well be caused by neighbor disturbance of the wireless signals. Maybe new neighbors and / or new equipment with higher power on different channels as before.
@banger did you perform a wireless survey?
Welcome To SNBForums
