Abject apologiesI [re]combined all the rules together into 1 file the firewall one and they seem to work
Currently 192.168.1.26 (only if forced through the VPN) should only be able to open in a web browser 'snbforums.com' or 'reddit.com'?but something is still not right as i can ping cnn.com
iptables --line -t filter -nvL FORWARD
iptables --line -t mangle -nvL PREROUTING
ip rule
grep Valid_VPN_IP /etc/dnsmasq.conf
grep Valid_VPN_IP /jffs/configs/dnsmasq.conf.add
ipset list Valid_VPN_IP
VPN_ID=1 # VPN Client 3
VPN_FWMARK="0x1000/0x1000" # 0x1000=VPN 1, 0x2000=VPN 2, 0x4000=VPN 1, 0x4000=VPN 3,
IPSET_NAME="Valid_VPN_IP"
iptables -t mangle -D PREROUTING -s $IPADDR -i br0 -m set --match-set $IPSET_NAME dst -j MARK --set-mark $VPN_FWMARK 2>/dev/null
iptables -t mangle -A PREROUTING -s $IPADDR -i br0 -m set --match-set $IPSET_NAME dst -j MARK --set-mark $VPN_FWMARK
Martineau,
Image attached.
Here is where I am confused.
If i remove the following lines from firewall-start (which I would like to do)
Code:VPN_ID=1 # VPN Client 3 VPN_FWMARK="0x1000/0x1000" # 0x1000=VPN 1, 0x2000=VPN 2, 0x4000=VPN 1, 0x4000=VPN 3, IPSET_NAME="Valid_VPN_IP" iptables -t mangle -D PREROUTING -s $IPADDR -i br0 -m set --match-set $IPSET_NAME dst -j MARK --set-mark $VPN_FWMARK 2>/dev/null iptables -t mangle -A PREROUTING -s $IPADDR -i br0 -m set --match-set $IPSET_NAME dst -j MARK --set-mark $VPN_FWMARK
Does that mean "I" would define when the traffic woud route through the vpn not the rules?
The PING protocol icmptype 8/0 is not the same as TCP 80/443 and in some rules need to be explicitly specified, but the blocking rules I provided defaults to ALL protocols.Also if i am able to actually ping cnn.com, does that mean the device can send data to cnn.com (or any other domain) via a API request instead of standard TCP request for port 80, but I just wouldn't see it but the data would be being sent.
Here are my current files2. There are no firewall BLOCKING rules for 192.168.1.26 to restrict access to domains thru VPNs
#!/bin/sh
IPADDR=192.168.2.26
iptables -D FORWARD -s $IPADDR -i br0 -p udp -m udp --dport 53 -j ACCEPT 2>/dev/null
iptables -D FORWARD -s $IPADDR -i br0 -o tun1+ -m set --match-set $IPSET_NAME dst -j ACCEPT -m comment --comment "ALLOWED_thru_VPN" 2>/dev/null
iptables -D FORWARD -s $IPADDR -i br0 -o tun1+ -m set ! --match-set $IPSET_NAME dst -j DROP -m comment --comment "BLOCKED_thru_VPN" 2>/dev/null
iptables -I FORWARD "$(($(iptables -nvL FORWARD --line -t filter | grep "state INVALID" | cut -d' ' -f1)+1))" -s $IPADDR -i br0 -o tun1+ -m set ! --match-set $IPSET_NAME dst -j DROP -m comment --comment "BLOCKED_thru_VPN"
iptables -I FORWARD "$(($(iptables -nvL FORWARD --line -t filter | grep "state INVALID" | cut -d' ' -f1)+1))" -s $IPADDR -i br0 -o tun1+ -m set --match-set $IPSET_NAME dst -j ACCEPT -m comment --comment "ALLOWED_thru_VPN"
iptables -I FORWARD "$(($(iptables -nvL FORWARD --line -t filter | grep "state INVALID" | cut -d' ' -f1)+1))" -s $IPADDR -i br0 -p udp -m udp --dport 53 -j ACCEPT
#!/bin/sh
modprobe -sv xt_comment.ko
ipset create $IPSET_NAME hash:net comment 2>/dev/null
#!/bin/sh
# These are optional, but if the doamins are defined in 'dnsmasq.conf.add' then dnsmasq will automatically populate the ipset, but will not include the comment description to help identify the IPs. (May be useful if you later want to remove a domain's IPs.)
for IP in $(nslookup "snbforums.com" | grep -oE '([0-9]{1,3}\.){3}[0-9]{1,3}' | grep -v "127.0.0.1");do ipset add $IPSET_NAME $IP comment snbforums.com;done;
for IP in $(nslookup "speedtest.net" | grep -oE '([0-9]{1,3}\.){3}[0-9]{1,3}' | grep -v "127.0.0.1");do ipset add $IPSET_NAME $IP comment speedtest.net;done;
for IP in $(nslookup "whatismyipaddress.com" | grep -oE '([0-9]{1,3}\.){3}[0-9]{1,3}' | grep -v "127.0.0.1");do ipset add $IPSET_NAME $IP comment whatismyipaddress.com;done;
Martineau,
What rules Do I need to write so be it through VPN or not through VPN to only allow specific websites
#!/bin/sh
IPADDR=192.168.2.26
logger -st "($(basename $0))" $$ "Creating IPSET '$IPSET_NAME' rules"
# Prevent duplicates but can leave firewall exposed...
iptables -D FORWARD -s $IPADDR -i br0 -o eth0 -m set --match-set $IPSET_NAME dst -j ACCEPT -m comment --comment "ALLOWED" 2>/dev/null
iptables -D FORWARD -s $IPADDR -i br0 -o eth0 -m set ! --match-set $IPSET_NAME dst -j DROP -m comment --comment "BLOCKED" 2>/dev/null
POS=$(($(iptables -nvL FORWARD --line -t filter | grep "state INVALID" | cut -d' ' -f1)+1))
# Rather than block ALL interfaces, apply rules to WAN (eth0) interface only
iptables -I FORWARD $POS -s $IPADDR -i br0 -o eth0 -m set ! --match-set $IPSET_NAME dst -j DROP -m comment --comment "BLOCKED"
iptables -I FORWARD $POS -s $IPADDR -i br0 -o eth0 -m set --match-set $IPSET_NAME dst -j ACCEPT -m comment --comment "ALLOWED"
iptables -I FORWARD $POS -s $IPADDR -i br0 -o eth0 -p icmp -m icmp --icmp-type 8 -j REJECT -m comment --comment "NoPING"
iptables -I FORWARD $POS -s $IPADDR -i br0 -p udp -m udp --dport 53 -j ACCEPT
Also I don't think the wan-start section works as dnsmasq is empty
echo "ipset=/www.siteiwanttoallow.com/Valid_VPN_IP" >>/jffs/configs/dnsmasq.conf.add
Nov 18 01:00:10 ntpd: Initial clock set
Nov 18 01:00:10 rc_service: ntpd_synced 620:notify_rc restart_diskmon
Nov 18 01:00:10 disk_monitor: Finish
Nov 18 01:00:12 disk_monitor: be idle
Nov 18 01:00:30 kernel: SHN Release Version: 2.0.1 890c91d
Nov 18 01:00:30 kernel: UDB Core Version: 0.2.18
Nov 18 01:00:30 kernel: sizeof forward pkt param = 192
Nov 18 01:00:30 BWDPI: fun bitmap = 3
Nov 18 01:00:34 rc_service: udhcpc 462:notify_rc start_firewall
Nov 18 01:00:36 dhcp_client: bound 192.168.1.4 via 192.168.1.1 during 86400 seconds.
Nov 18 01:00:36 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Nov 18 01:00:37 custom_script: Running /jffs/scripts/firewall-start (args: eth0)
Nov 18 01:00:42 crond[245]: time disparity of 809335 minutes detected
Nov 18 01:01:06 rc_service: amas_lib 364:notify_rc restart_firewall
Nov 18 01:01:07 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Nov 18 01:01:08 custom_script: Running /jffs/scripts/firewall-start (args: eth0)
It's not weird - simply working as designed.Is it weird that firewall start runs 2x
I have updated the list of diagnostic/debugging commands in post #23, so you will need to provide the output of those commands when things appear 'weird'.I followed all your steps and can't seem to figure out for the life of me what is still wrong.
admin@RT-AC68U-1340:/tmp/home/root# iptables --line -t filter -nvL FORWARD
Chain FORWARD (policy DROP 0 packets, 0 bytes)
num pkts bytes target prot opt in out source destina tion
1 42192 15M ACCEPT all -- * * 0.0.0.0/0 0.0.0.0 /0 state RELATED,ESTABLISHED
2 0 0 other2wan all -- !br0 eth0 0.0.0.0/0 0.0.0.0 /0
3 0 0 ACCEPT all -- br0 br0 0.0.0.0/0 0.0.0.0 /0
4 171 14396 DROP all -- * * 0.0.0.0/0 0.0.0.0 /0 state INVALID
5 0 0 ACCEPT udp -- br0 * 192.168.2.26 0.0.0.0 /0 udp dpt:53
6 2694 353K NSFW all -- * * 0.0.0.0/0 0.0.0.0 /0
7 2694 353K ACCEPT all -- br0 * 0.0.0.0/0 0.0.0.0 /0
8 0 0 ACCEPT all -- * * 0.0.0.0/0 0.0.0.0 /0 ctstate DNAT
9 0 0 OVPN all -- * * 0.0.0.0/0 0.0.0.0 /0 state NEW
10 0 0 DROP all -- * * 0.0.0.0/0 0.0.0.0
admin@RT-AC68U-1340:/tmp/home/root# iptables --line -t mangle -nvL PREROUTING
Chain PREROUTING (policy ACCEPT 59632 packets, 18M bytes)
num pkts bytes target prot opt in out source destination
admin@RT-AC68U-1340:/tmp/home/root# ip rule
0: from all lookup local
32766: from all lookup main
32767: from all lookup default
admin@RT-AC68U-1340:/tmp/home/root# grep Valid_VPN_IP /etc/dnsmasq.conf
ipset=/www.cnn.com/Valid_VPN_IP
ipset=/www.snbforums.com/Valid_VPN_IP
admin@RT-AC68U-1340:/tmp/home/root# grep Valid_VPN_IP /jffs/configs/dnsmasq.conf.add
admin@RT-AC68U-1340:/tmp/home/root# ipset list Valid_VPN_IP
ipset v6.32: The set with the given name does not exist
firewall-start
#!/bin/sh
IPADDR=192.168.2.26
iptables -D FORWARD -s $IPADDR -i br0 -m set --match-set $IPSET_NAME dst -j ACCEPT -m comment --comment "ALLOWED_thru_ANY" 2>/dev/null
iptables -D FORWARD -s $IPADDR -i br0 -m set ! --match-set $IPSET_NAME dst -j DROP -m comment --comment "BLOCKED_thru_ANY" 2>/dev/null
iptables -I FORWARD "$(($(iptables -nvL FORWARD --line -t filter | grep "state INVALID" | cut -d' ' -f1)+1))" -s $IPADDR -i br0 -m set ! --match-set $IPSET_NAME dst -j DROP -m comment --comment "BLOCKED_thru_ANY"
iptables -I FORWARD "$(($(iptables -nvL FORWARD --line -t filter | grep "state INVALID" | cut -d' ' -f1)+1))" -s $IPADDR -i br0 -m set --match-set $IPSET_NAME dst -j ACCEPT -m comment --comment "ALLOWED_thru_ANY"
init-start
#!/bin/sh
wan-start
#!/bin/sh
IP=192.168.2.26
for IP in $(nslookup "cnn.com" | grep -oE '([0-9]{1,3}\.){3}[0-9]{1,3}' | grep -v "127.0.0.1");do ipset add $IPSET_NAME $IP comment cnn.com;done;
It appears that you are not creating IPSET Valid_VPN_IP (init-start) during the boot process, consequently you are missing the ACCEPT/BLOCK firewall rules, as they can't be created (firewall-start) if they refer to an invalid IPSET.Martineau,
Debug Info added below from the commands requested along with the source of all 3 files I made with what is running at the moment.
P.S. I noticed in the wan-start there was no definition of IP nor IPSET_NAME so I created variables and added them in and rebooted.
For some reason now when I hardcoded the IP i lost ALL Internet on my device and wasn't able to ping any site.
I also noticed the IPSET was empty(I thought the wan start command would populate the IPSET automatically from dnsmasq as you said when I added the variables, but it didn't)
Thanks again for your time.
Code:admin@RT-AC68U-1340:/tmp/home/root# iptables --line -t filter -nvL FORWARD Chain FORWARD (policy DROP 0 packets, 0 bytes) num pkts bytes target prot opt in out source destina tion 1 42192 15M ACCEPT all -- * * 0.0.0.0/0 0.0.0.0 /0 state RELATED,ESTABLISHED 2 0 0 other2wan all -- !br0 eth0 0.0.0.0/0 0.0.0.0 /0 3 0 0 ACCEPT all -- br0 br0 0.0.0.0/0 0.0.0.0 /0 4 171 14396 DROP all -- * * 0.0.0.0/0 0.0.0.0 /0 state INVALID 5 0 0 ACCEPT udp -- br0 * 192.168.2.26 0.0.0.0 /0 udp dpt:53 6 2694 353K NSFW all -- * * 0.0.0.0/0 0.0.0.0 /0 7 2694 353K ACCEPT all -- br0 * 0.0.0.0/0 0.0.0.0 /0 8 0 0 ACCEPT all -- * * 0.0.0.0/0 0.0.0.0 /0 ctstate DNAT 9 0 0 OVPN all -- * * 0.0.0.0/0 0.0.0.0 /0 state NEW 10 0 0 DROP all -- * * 0.0.0.0/0 0.0.0.0 admin@RT-AC68U-1340:/tmp/home/root# iptables --line -t mangle -nvL PREROUTING Chain PREROUTING (policy ACCEPT 59632 packets, 18M bytes) num pkts bytes target prot opt in out source destination admin@RT-AC68U-1340:/tmp/home/root# ip rule 0: from all lookup local 32766: from all lookup main 32767: from all lookup default admin@RT-AC68U-1340:/tmp/home/root# grep Valid_VPN_IP /etc/dnsmasq.conf ipset=/www.cnn.com/Valid_VPN_IP ipset=/www.snbforums.com/Valid_VPN_IP admin@RT-AC68U-1340:/tmp/home/root# grep Valid_VPN_IP /jffs/configs/dnsmasq.conf.add ipset=/www.cnn.com/Valid_VPN_IP ipset=/www.snbforums.com/Valid_VPN_IP admin@RT-AC68U-1340:/tmp/home/root# ipset list Valid_VPN_IP ipset v6.32: The set with the given name does not exist firewall-start #!/bin/sh IPADDR=192.168.2.26 IPSET_NAME="Valid_VPN_IP" iptables -D FORWARD -s $IPADDR -i br0 -p udp -m udp --dport 53 -j ACCEPT 2>/dev/null iptables -D FORWARD -s $IPADDR -i br0 -m set --match-set $IPSET_NAME dst -j ACCEPT -m comment --comment "ALLOWED_thru_ANY" 2>/dev/null iptables -D FORWARD -s $IPADDR -i br0 -m set ! --match-set $IPSET_NAME dst -j DROP -m comment --comment "BLOCKED_thru_ANY" 2>/dev/null iptables -I FORWARD "$(($(iptables -nvL FORWARD --line -t filter | grep "state INVALID" | cut -d' ' -f1)+1))" -s $IPADDR -i br0 -m set ! --match-set $IPSET_NAME dst -j DROP -m comment --comment "BLOCKED_thru_ANY" iptables -I FORWARD "$(($(iptables -nvL FORWARD --line -t filter | grep "state INVALID" | cut -d' ' -f1)+1))" -s $IPADDR -i br0 -m set --match-set $IPSET_NAME dst -j ACCEPT -m comment --comment "ALLOWED_thru_ANY" iptables -I FORWARD "$(($(iptables -nvL FORWARD --line -t filter | grep "state INVALID" | cut -d' ' -f1)+1))" -s $IPADDR -i br0 -p udp -m udp --dport 53 -j ACCEPT init-start #!/bin/sh modprobe -sv xt_comment.ko IPSET_NAME="Valid_VPN_IP" ipset create $IPSET_NAME hash:net comment 2>/dev/null wan-start #!/bin/sh IP=192.168.2.26 IPSET_NAME="Valid_VPN_IP" # These are optional, but if the doamins are defined in 'dnsmasq.conf.add' then dnsmasq will automatically populate the ipset, but will not include the comment description to help identify the IPs. (May be useful if you later want to remove a domain's IPs.) for IP in $(nslookup "snbforums.com" | grep -oE '([0-9]{1,3}\.){3}[0-9]{1,3}' | grep -v "127.0.0.1");do ipset add $IPSET_NAME $IP comment snbforums.com;done; for IP in $(nslookup "cnn.com" | grep -oE '([0-9]{1,3}\.){3}[0-9]{1,3}' | grep -v "127.0.0.1");do ipset add $IPSET_NAME $IP comment cnn.com;done;
<snip>
9 1 80 logdrop all -- * * 0.0.0.0/0 0.0.0.0/0 state INVALID
10 0 0 ACCEPT udp -- br0 * 192.168.2.26 0.0.0.0/0 udp dpt:53
11 0 0 ACCEPT all -- br0 * 192.168.2.26 0.0.0.0/0 match-set Valid_VPN_IP dst /* ALLOWED_thru_ANY */
12 0 0 DROP all -- br0 * 192.168.2.26 0.0.0.0/0 ! match-set Valid_VPN_IP dst /* BLOCKED_thru_ANY */
chmod a+rx /jffs/scripts/init-start
chmod a+rx /jffs/scripts/wan-start
1 8490 2866K ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 state RELATED,ESTABLISHED
2 0 0 other2wan all -- !br0 eth0 0.0.0.0/0 0.0.0.0/0
3 0 0 ACCEPT all -- br0 br0 0.0.0.0/0 0.0.0.0/0
4 20 920 DROP all -- * * 0.0.0.0/0 0.0.0.0/0 state INVALID
5 0 0 ACCEPT udp -- br0 * 192.168.2.26 0.0.0.0/0 udp dpt:53
6 346 102K NSFW all -- * * 0.0.0.0/0 0.0.0.0/0
7 346 102K ACCEPT all -- br0 * 0.0.0.0/0 0.0.0.0/0
8 0 0 ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 ctstate DNAT
9 0 0 OVPN all -- * * 0.0.0.0/0 0.0.0.0/0 state NEW
10 0 0 DROP all -- * * 0.0.0.0/0 0.0.0.0/0
Chain PREROUTING (policy ACCEPT 16569 packets, 3798K bytes)
1 0 0 MARK all -- tun21 * 0.0.0.0/0 0.0.0.0/0 MARK xset 0x1/0x7
ipset=/www.whatismyipaddress.com/Valid_VPN_IP
ipset=/www.speedtest.net/Valid_VPN_IP
Type: hash:net
Revision: 6
Header: family inet hashsize 1024 maxelem 65536 comment
Size in memory: 554
References: 0
Number of entries: 3
Members:
104.27.126.97
104.27.127.97
8.8.8.8 comment "snbforums.com"
#!/bin/sh
logger -st "($(basename $0))" $$ "Adding domains to IPSET $IPSET_NAME"
#!/bin/sh
IPADDR=192.168.2.26
# Non-destructive (but no less exposed?) method to prevent duplicates
#[ iptables -C FORWARD -i br0 -o tun1+ -m set ! --match-set $IPSET_NAME dst -j DROP -m comment --comment "BLOCKED_thru_VPN" 2>/dev/null ] || iptables -I FORWARD "$(($(iptables -nvL FORWARD --line -t filter | grep "state INVALID" | cut -d' ' -f1)+1))" -s $IPADDR -i br0 -o tun1+ -m set ! --match-set $IPSET_NAME dst -j DROP -m comment --comment "BLOCKED_thru_VPN"
#[ iptables -C FORWARD -s $IPADDR -i br0 -o tun1+ -m set --match-set $IPSET_NAME dst -j ACCEPT -m comment --comment "ALLOWED_thru_VPN" 2>/dev/null ] || iptables -I FORWARD "$(($(iptables -nvL FORWARD --line -t filter | grep "state INVALID" | cut -d' ' -f1)+1))" -s $IPADDR -i br0 -o tun1+ -m set --match-set $IPSET_NAME dst -j ACCEPT -m comment --comment "ALLOWED_thru_VPN"
#[ iptables -C FORWARD -s $IPADDR -i br0 -p udp -m udp --dport 53 -j ACCEPT 2>/dev/null ] || iptables -I FORWARD "$(($(iptables -nvL FORWARD --line -t filter | grep "state INVALID" | cut -d' ' -f1)+1))" -s $IPADDR -i br0 -p udp -m udp --dport 53 -j ACCEPT
#!/bin/sh
logger -st "($(basename $0))" $$ "Creating IPSET $IPSET_NAME"
echo "ipset=/www.snbforums.com/Valid_VPN_IP" >>/jffs/configs/dnsmasq.conf.add
echo "ipset=/www.whatismyipaddress.com/Valid_VPN_IP" >>/jffs/configs/dnsmasq.conf.add
echo "ipset=/www.speedtest.net/Valid_VPN_IP" >>/jffs/configs/dnsmasq.conf.add
service restart_dnsmasq
e.g. '-t filter FORWARD' chain to block 192.168.2.26 outbound through ANY interface should look something like this...
I suspect that not ALL of the scripts you have created are marked as 'executable'Code:<snip> 9 1 80 logdrop all -- * * 0.0.0.0/0 0.0.0.0/0 state INVALID 10 0 0 ACCEPT udp -- br0 * 192.168.2.26 0.0.0.0/0 udp dpt:53 11 0 0 ACCEPT all -- br0 * 192.168.2.26 0.0.0.0/0 match-set Valid_VPN_IP dst /* ALLOWED_thru_ANY */ 12 0 0 DROP all -- br0 * 192.168.2.26 0.0.0.0/0 ! match-set Valid_VPN_IP dst /* BLOCKED_thru_ANY */
(as instructed in the single global command at the bottom of post #10), or you can individually explicitly make each one executable:
Code:chmod a+rx /jffs/scripts/init-start chmod a+rx /jffs/scripts/wan-start
Thanks for the heads-up! I've updated wan-start code in post #10 which indeed omitted the name of the IPSET to store the retrieved domain IPs![]()
Martineau,
Thanks for your help, Im sorry i wasn't able to post sooner, was busy. Here the most recent debug commands and my current files with the VPN section removed as i wanted to control that.
I readded
to firewall start as it wasn't there in post 10.
I will reboot again now and see if all is correct.
Updated Debug Commands below:
Code:admin@RT-AC68U-1340:/tmp/home/root# iptables --line -t filter -nvL FORWARD Chain FORWARD (policy DROP 0 packets, 0 bytes) num pkts bytes target prot opt in out source destination 1 8490 2866K ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 state RELATED,ESTABLISHED 2 0 0 other2wan all -- !br0 eth0 0.0.0.0/0 0.0.0.0/0 3 0 0 ACCEPT all -- br0 br0 0.0.0.0/0 0.0.0.0/0 4 20 920 DROP all -- * * 0.0.0.0/0 0.0.0.0/0 state INVALID 5 0 0 ACCEPT udp -- br0 * 192.168.2.26 0.0.0.0/0 udp dpt:53 6 346 102K NSFW all -- * * 0.0.0.0/0 0.0.0.0/0 7 346 102K ACCEPT all -- br0 * 0.0.0.0/0 0.0.0.0/0 8 0 0 ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 ctstate DNAT 9 0 0 OVPN all -- * * 0.0.0.0/0 0.0.0.0/0 state NEW 10 0 0 DROP all -- * * 0.0.0.0/0 0.0.0.0/0 admin@RT-AC68U-1340:/tmp/home/root# admin@RT-AC68U-1340:/tmp/home/root# iptables --line -t mangle -nvL PREROUTING Chain PREROUTING (policy ACCEPT 16569 packets, 3798K bytes) num pkts bytes target prot opt in out source destination 1 0 0 MARK all -- tun21 * 0.0.0.0/0 0.0.0.0/0 MARK xset 0x1/0x7 admin@RT-AC68U-1340:/tmp/home/root# admin@RT-AC68U-1340:/tmp/home/root# ip rule 0: from all lookup local 32766: from all lookup main 32767: from all lookup default admin@RT-AC68U-1340:/tmp/home/root# admin@RT-AC68U-1340:/tmp/home/root# grep Valid_VPN_IP /etc/dnsmasq.conf ipset=/www.snbforums.com/Valid_VPN_IP ipset=/www.whatismyipaddress.com/Valid_VPN_IP ipset=/www.speedtest.net/Valid_VPN_IP admin@RT-AC68U-1340:/tmp/home/root# admin@RT-AC68U-1340:/tmp/home/root# grep Valid_VPN_IP /jffs/configs/dnsmasq.conf.add ipset=/www.snbforums.com/Valid_VPN_IP ipset=/www.whatismyipaddress.com/Valid_VPN_IP ipset=/www.speedtest.net/Valid_VPN_IP admin@RT-AC68U-1340:/tmp/home/root# admin@RT-AC68U-1340:/tmp/home/root# ipset list Valid_VPN_IP Name: Valid_VPN_IP Type: hash:net Revision: 6 Header: family inet hashsize 1024 maxelem 65536 comment Size in memory: 554 References: 0 Number of entries: 3 Members: 104.27.126.97 104.27.127.97 8.8.8.8 comment "snbforums.com" admin@RT-AC68U-1340:/tmp/home/root#
wan-start file
Code:#!/bin/sh # These are optional, but if the doamins are defined in 'dnsmasq.conf.add' then dnsmasq will automatically populate the ipset, but will not include the comment description to help identify the IPs. (May be useful if you later want to remove a domain's IPs.) IPSET_NAME="Valid_VPN_IP" logger -st "($(basename $0))" $$ "Adding domains to IPSET $IPSET_NAME" for IP in $(nslookup "snbforums.com" | grep -oE '([0-9]{1,3}\.){3}[0-9]{1,3}' | grep -v "127.0.0.1");do ipset add $IPSET_NAME $IP comment snbforums.com;done; for IP in $(nslookup "speedtest.net" | grep -oE '([0-9]{1,3}\.){3}[0-9]{1,3}' | grep -v "127.0.0.1");do ipset add $IPSET_NAME $IP comment speedtest.net;done; for IP in $(nslookup "whatismyipaddress.com" | grep -oE '([0-9]{1,3}\.){3}[0-9]{1,3}' | grep -v "127.0.0.1");do ipset add $IPSET_NAME $IP comment whatismyipaddress.com;done;
firewall-start file
Code:#!/bin/sh IPADDR=192.168.2.26 IPSET_NAME="Valid_VPN_IP" # Prevent duplicates but can leave firewall exposed... iptables -D FORWARD -s $IPADDR -i br0 -p udp -m udp --dport 53 -j ACCEPT 2>/dev/null iptables -D FORWARD -s $IPADDR -i br0 -o tun1+ -m set --match-set $IPSET_NAME dst -j ACCEPT -m comment --comment "ALLOWED_thru_VPN" 2>/dev/null iptables -D FORWARD -s $IPADDR -i br0 -o tun1+ -m set ! --match-set $IPSET_NAME dst -j DROP -m comment --comment "BLOCKED_thru_VPN" 2>/dev/null iptables -I FORWARD "$(($(iptables -nvL FORWARD --line -t filter | grep "state INVALID" | cut -d' ' -f1)+1))" -s $IPADDR -i br0 -o tun1+ -m set ! --match-set $IPSET_NAME dst -j DROP -m comment --comment "BLOCKED_thru_VPN" iptables -I FORWARD "$(($(iptables -nvL FORWARD --line -t filter | grep "state INVALID" | cut -d' ' -f1)+1))" -s $IPADDR -i br0 -o tun1+ -m set --match-set $IPSET_NAME dst -j ACCEPT -m comment --comment "ALLOWED_thru_VPN" iptables -I FORWARD "$(($(iptables -nvL FORWARD --line -t filter | grep "state INVALID" | cut -d' ' -f1)+1))" -s $IPADDR -i br0 -p udp -m udp --dport 53 -j ACCEPT # Non-destructive (but no less exposed?) method to prevent duplicates #[ iptables -C FORWARD -i br0 -o tun1+ -m set ! --match-set $IPSET_NAME dst -j DROP -m comment --comment "BLOCKED_thru_VPN" 2>/dev/null ] || iptables -I FORWARD "$(($(iptables -nvL FORWARD --line -t filter | grep "state INVALID" | cut -d' ' -f1)+1))" -s $IPADDR -i br0 -o tun1+ -m set ! --match-set $IPSET_NAME dst -j DROP -m comment --comment "BLOCKED_thru_VPN" #[ iptables -C FORWARD -s $IPADDR -i br0 -o tun1+ -m set --match-set $IPSET_NAME dst -j ACCEPT -m comment --comment "ALLOWED_thru_VPN" 2>/dev/null ] || iptables -I FORWARD "$(($(iptables -nvL FORWARD --line -t filter | grep "state INVALID" | cut -d' ' -f1)+1))" -s $IPADDR -i br0 -o tun1+ -m set --match-set $IPSET_NAME dst -j ACCEPT -m comment --comment "ALLOWED_thru_VPN" #[ iptables -C FORWARD -s $IPADDR -i br0 -p udp -m udp --dport 53 -j ACCEPT 2>/dev/null ] || iptables -I FORWARD "$(($(iptables -nvL FORWARD --line -t filter | grep "state INVALID" | cut -d' ' -f1)+1))" -s $IPADDR -i br0 -p udp -m udp --dport 53 -j ACCEPT
init-start file
Code:#!/bin/sh modprobe -sv xt_comment.ko IPSET_NAME="Valid_VPN_IP" logger -st "($(basename $0))" $$ "Creating IPSET $IPSET_NAME" ipset create $IPSET_NAME hash:net comment 2>/dev/null
I cleared out the dnsmasq.conf.add file , I rebooted the router to trigger all 3 files below to run, and then noticed the dnsmasq.conf.add was empty so i ran the following 3 lines one by one:
Code:echo "ipset=/www.snbforums.com/Valid_VPN_IP" >>/jffs/configs/dnsmasq.conf.add echo "ipset=/www.whatismyipaddress.com/Valid_VPN_IP" >>/jffs/configs/dnsmasq.conf.add echo "ipset=/www.speedtest.net/Valid_VPN_IP" >>/jffs/configs/dnsmasq.conf.add service restart_dnsmasq
Always - no exceptions.Case sensitivity matters....?
How did you manage to get '8.8.8.8 comment "snbforums.com"' into IPSET Valid_VPN_IP?Code:ipset list Valid_VPN_IP Name: Valid_VPN_IP Type: hash:net Revision: 6 Header: family inet hashsize 1024 maxelem 65536 comment Size in memory: 554 References: 0 Number of entries: 3 Members: 104.27.126.97 104.27.127.97 8.8.8.8 comment "snbforums.com"
for IP in $(nslookup "8.8.8.8" | grep -oE '([0-9]{1,3}\.){3}[0-9]{1,3}' | grep -v "127.0.0.1");do ipset add Valid_VPN_IP $IP comment snbforums.com;done;
Something is still off with firewall start as the other 3 lines in ip filter nvl forward don't show.
cd /jffs/scripts
ls -lah *-start
sh -x ./init-start
sh -x ./firewall-start
sh -x ./wan-start
I bet his WAN DNS is 8.8.8.8 and grabbing it from nslookup Server: line.How did you manage to get '8.8.8.8 comment "snbforums.com"' into IPSET Valid_VPN_IP?![]()
# nslookup snbforums.com
Server: 9.9.9.9
Address 1: 9.9.9.9 dns9.quad9.net
Address 1: 2606:4700:20::681b:7e61
Address 2: 104.27.126.97
Address 3: 104.27.127.97
# nslookup snbforums.com | grep -oE '([0-9]{1,3}\.){3}[0-9]{1,3}'
9.9.9.9
9.9.9.9
104.27.126.97
104.27.127.97
Doh!I bet his WAN DNS is 8.8.8.8 and grabbing it from nslookup Server: line.
Code:# nslookup snbforums.com Server: 9.9.9.9 Address 1: 9.9.9.9 dns9.quad9.net Name: snbforums.com Address 1: 2606:4700:20::681b:7e61 Address 2: 104.27.126.97 Address 3: 104.27.127.97 # nslookup snbforums.com | grep -oE '([0-9]{1,3}\.){3}[0-9]{1,3}' 9.9.9.9 9.9.9.9 104.27.126.97 104.27.127.97
When I ran it, my dns was 75.75.75.75 also added as snbforums.comDoh!- clearly your post #19 didn't pick it up!
ASUSWRT-Merlin RT-AC68U 384.13-0 Wed Jul 31 17:27:27 UTC 2019
admin@RT-AC68U-1340:/tmp/home/root# cd /jffs/scripts
admin@RT-AC68U-1340:/jffs/scripts#
admin@RT-AC68U-1340:/jffs/scripts# ls -lah *-start
-rwxr-xr-x 1 admin root 2.1K Nov 22 11:59 firewall-start
-rwxr-xr-x 1 admin root 181 Nov 22 11:03 init-start
-rwxr-xr-x 1 admin root 859 Nov 22 11:03 wan-start
admin@RT-AC68U-1340:/jffs/scripts# ipset list Valid_VPN_IP
Type: hash:net
Revision: 6
Size in memory: 410
References: 2
Number of entries: 1
Members:
admin@RT-AC68U-1340:/jffs/scripts# sh -x ./init-start
+ modprobe -sv xt_comment.ko
+ IPSET_NAME=Valid_VPN_IP
+ basename ./init-start
+ logger -st (init-start) 1817 Creating IPSET Valid_VPN_IP
(init-start): 1817 Creating IPSET Valid_VPN_IP
+ ipset create Valid_VPN_IP hash:net comment
admin@RT-AC68U-1340:/jffs/scripts# sh -x ./firewall-start
+ IPADDR=192.168.2.26
+ iptables -D FORWARD -s 192.168.2.26 -i br0 -p udp -m udp --dport 53 -j ACCEPT
+ iptables -D FORWARD -s 192.168.2.26 -i br0 -o tun1+ -m set --match-set Valid_VPN_IP dst -j ACCEPT -m comment --comment ALLOWED_thru_VPN
+ iptables -D FORWARD -s 192.168.2.26 -i br0 -o tun1+ -m set ! --match-set Valid_VPN_IP dst -j DROP -m comment --comment BLOCKED_thru_VPN
+ iptables -nvL FORWARD --line -t filter
+ grep state INVALID
+ cut -d -f1
+ iptables -I FORWARD 5 -s 192.168.2.26 -i br0 -o tun1+ -m set ! --match-set Valid_VPN_IP dst -j DROP -m comment --comment BLOCKED_thru_VPN
+ cut -d -f1
+ iptables -I FORWARD 5 -s 192.168.2.26 -i br0 -o tun1+ -m set --match-set Valid_VPN_IP dst -j ACCEPT -m comment --comment ALLOWED_thru_VPN
+ cut -d -f1
+ iptables -I FORWARD 5 -s 192.168.2.26 -i br0 -p udp -m udp --dport 53 -j ACCEPT
admin@RT-AC68U-1340:/jffs/scripts# sh -x ./wan-start
+ basename ./wan-start
+ logger -st (wan-start) 1842 Adding domains to IPSET Valid_VPN_IP
(wan-start): 1842 Adding domains to IPSET Valid_VPN_IP
+ nslookup snbforums.com
+ grep -oE ([0-9]{1,3}\.){3}[0-9]{1,3}
+ grep -v 127.0.0.1
+ ipset add Valid_VPN_IP 8.8.8.8 comment snbforums.com
ipset v6.32: Element cannot be added to the set: it's already added
+ ipset add Valid_VPN_IP 104.27.127.97 comment snbforums.com
+ ipset add Valid_VPN_IP 104.27.126.97 comment snbforums.com
+ nslookup speedtest.net
+ grep -v 127.0.0.1
+ ipset add Valid_VPN_IP 8.8.8.8 comment speedtest.net
+ ipset add Valid_VPN_IP 151.101.130.219 comment speedtest.net
+ ipset add Valid_VPN_IP 151.101.2.219 comment speedtest.net
+ ipset add Valid_VPN_IP 151.101.194.219 comment speedtest.net
+ ipset add Valid_VPN_IP 151.101.66.219 comment speedtest.net
+ nslookup whatismyipaddress.com
+ grep -v 127.0.0.1
+ ipset add Valid_VPN_IP 8.8.8.8 comment whatismyipaddress.com
+ ipset add Valid_VPN_IP 104.16.154.36 comment whatismyipaddress.com
+ ipset add Valid_VPN_IP 104.16.155.36 comment whatismyipaddress.com
Welcome To SNBForums
