OzarkEdge
Part of the Furniture
without the fans I'm seeing a temp exceeding 80c
Core temp reports 84c here for my holdout AC86U.
Does http://router.asus.com/ajax_coretmp.asp work on an AX86U and has anyone noted its temp?
OE
dont care as my AX86U is arriving tomorrow.
Yup, it doesCore temp reports 84c here for my holdout AC86U.
OE
Tested on the AX86U:Core temp reports 84c here for my holdout AC86U.
OE
The AX86U
cpuTemp = "65.514"
How can i see the temp of the node? (AC86U)That's much better than my AC86U. Thanks!
OE
+1 SAME question.How can i see the temp of the node? (AC86U)
Checked my remote AC86U at 56.4 degrees. The folks are away with the temp set back.That's much better than my AC86U. Thanks!
OE
Sorry about that I just saw a 20c increase and I was startled. To clarify again, I was using cooling fans that stopped working so it's an issue that has nothing to do with the new firmware.Oh no, this is turning into yet another temperature thread....
On my end: fanctrl_info = ; curr_cpuTemp = "76.798"; curr_rxData = fanctrl_info[3]; curr_coreTmp_2 = fanctrl_info[1]; curr_coreTmp_5 = fanctrl_info[2];never mind. turns out the fans stopped working complexlyI'm using this link to see the temp
without the fans I'm seeing a temp exceeding 80c, before that my temps never got over 60c
same for my AC86U. When i enable eee then temp is lower about 2 degree.On my end: fanctrl_info = ; curr_cpuTemp = "76.798"; curr_rxData = fanctrl_info[3]; curr_coreTmp_2 = fanctrl_info[1]; curr_coreTmp_5 = fanctrl_info[2];
Is it really fine though? I love this router but from what I'm reading online here and in other places this router is getting bricked all the time. If it's not the temps then something else is causing all these bricked Routers.Temp issue again?
Somebody is coming soon.
"It's ok. That's normal. Your router is fine"
temperatures is ok for this build.Is it really fine though? I love this router but from what I'm reading online here and in other places this router is getting bricked all the time. If it's not the temps then something else is causing all these bricked Routers.
Welcome To SNBForums
