Version 3.0.0.4.384.45149
2018/12/05 60.66 MBytes
ASUS RT-AC86U Firmware version 3.0.0.4.384.45149
AiMesh
- Improved AiMesh stability
- Lyra, Lyra Mini, and Lyra Trio can be added as AiMesh node into RT-AC86U network.
Please refer to https://www.asus.com/support/FAQ/1038071 for more detail.
Security
- Fixed CVE-2018-14710, CVE-2018-14711, CVE-2018-14712, CVE-2018-14713, CVE-2018-14714. Thanks for Rick Ramgattie's contribution.
- Fixed AiCloud/ Samba account vulnerability. Thanks for Matthew Cundari's contribution.
- Fixed DoS vulnerability. Thanks for Ruikai Liu's contribution.
- Fixed CVE-2018-17020, CVE-2018-17021, CVE-2018-17022.
- Fixed stored XSS vulnerability. Thanks for Duda Przemyslaw's contribution.
- Updated OpenSSL library.
New Alexa skill and IFTTT actions
- Add Alexa skill “ ask ASUS ROUTER to report security status”
- Add Alexa skill “ ask ASUS ROUTER how many devices are online”
- Add IFTTT actions : Wake on LAN
- Add IFTTT actions : check new firmware available and upgrade
[Note] You have to upgrade the firmware version up to 3.0.0.4.384_45149 if you want to use these new Alexa skills and IFTTT actions.
Bug fixes and improvement
- Improved wireless stability.
- Modified “Dual Wan” user interface.
- Modified “Port Forwarding” user interface.
- Modified “Restore” user interface.
- Fixed GUI bugs on user feedback page.
- Fixed “Adaptive QoS” bugs.
Please unzip the firmware file first then check the MD5 code.
MD5: 1ca78fe37882cac19fbf9c5a50cb2c0f
Download Link: https://www.asus.com/us/Networking/RT-AC86U/HelpDesk_Download/
Go though OS list until you find the new firmware. Asus usually adds it to the 32-Bit versions first.
AiMesh
Security
