ASUS RT-AC86U firmware release 3.0.0.4.384.45149 12/05/2018
RT-AC68U
firmware:3.0.0.4.384_45149
After the installation of the restored factory settings. No icon to access the downloadmaster, not always can be applied to change the name of the client.
I'm also getting these crashes. I have a single 86U with QoS and Firewall disabled, and I also did a factory reset. I am also not using AiMesh... just regular home setup.
Dec 9 07:37:25 kernel: pgd = ffffffc0115bd000
Dec 9 07:37:25 kernel: [00000000] *pgd=000000000917b003, *pud=000000000917b003, *pmd=000000000bbb9003, *pte=0000000000000000
Dec 9 07:37:25 kernel: CPU: 1 PID: 15803 Comm: dcd Tainted: P O 4.1.27 #2
Dec 9 07:37:25 kernel: Hardware name: Broadcom-v8A (DT)
Dec 9 07:37:25 kernel: task: ffffffc0192e8080 ti: ffffffc00917c000 task.ti: ffffffc00917c000
Dec 9 07:37:25 kernel: PC is at 0xf7028f44
Dec 9 07:37:25 kernel: LR is at 0x1dc74
Dec 9 07:37:25 kernel: pc : [<00000000f7028f44>] lr : [<000000000001dc74>] pstate: 600e0010
Dec 9 07:37:25 kernel: sp : 00000000ffd41a88
Dec 9 07:37:25 kernel: x12: 000000000009ff10
Dec 9 07:37:25 kernel: x11: 00000000f62ff024 x10: 00000000000a02b4
Dec 9 07:37:25 kernel: x9 : 00000000f62ffca4 x8 : 00000000000a076c
Dec 9 07:37:25 kernel: x7 : 00000000f62ffcdc x6 : 00000000000a0766
Dec 9 07:37:25 kernel: x5 : 0000000000000000 x4 : 00000000f62ffc88
Dec 9 07:37:25 kernel: x3 : 0000000000000000 x2 : 0000000000000000
Dec 9 07:37:25 kernel: x1 : 000000000007c674 x0 : 0000000000000000
...I also see a constant "Assoc" and "Disassoc" messages with a MAC address appended to each within the system Log every 5-10 min. Not sure if there's a relation.
These messages appear to be documenting when devices join or leave the wireless networks. ASUS didn't seem to be logging this information in previous firmwares. Maybe it was accidental for this firmware.
Buy the RT-AC86u 5 days ago and when turning on the router, IPv6 works correctly for a few minutes, then it does not work.?
When IPv6 works the routing table shows the default route (WAN IPv6 Gateway), when IPv6 stops working the line with the default route (WAN IPv6 Gateway) disappears.
All this happens in official firmware. versions: 3.0.0.4.384.45149, 3.0.0.4.384.32799, I do not know if in previous versions it happens.
Also try the latest version of Asus merlin and the same thing happens.
(Excuse my language, my native language is Spanish)
My internet connection is VDSL2 50mbps down / 10mbps up.
My configuration is as follows: ISP -> Modem Huawei HG659 (In bridge mode) -> Asus RT-AC86U.
My ISP is DualStack (IPv4/IPv6), IPv6 Connection Type: Native with DHCP-PD
Is it normal to have these 3 lines in the System Log every time you start or stop AIProtection?
Dec 9 17:38:03 modprobe: module ip6t_REJECT not found in modules.dep
Dec 9 17:38:03 modprobe: module ip6t_ROUTE not found in modules.dep
Dec 9 17:38:03 modprobe: module ip6t_LOG not found in modules.dep
I do use IPv6 and it appears to be working properly. All clients get 19/20 on ipv6-test.com.
I use IPv6, I do not use aiprotection, but I've seen those lines in the log
ASUS RT-AC86U firmware version 3.0.0.4.384.45149
I uploaded this firmware manually to my node and then to my router. No resets. This firmware appears to resolve my issue first reported here.
My Win10 Intel Tri-Band Wireless-AC 18265 adapter link rate at the node still drops briefly once or twice per speed test from 866 to 780 before recovering to 866. During many repeated tests, I saw link rate 650 once and 390 once. I never see this link rate fluctuation at the router. All speed tests passed at about 115/11 (nominal is 100/10); the ping is a little longer at the node.
OE
hmm....today my android app says that AIProtection is disabled ???
Strange, becouse i always turn on AIProtection.
For RT-AC86U and GT-AC5300. Try to turn off the AiProtection.
ernel: x5 : 0000000000000000 x4 : 00000000f63ffcf8
Dec 12 05:41:27 kernel: x3 : 0000000000000000 x2 : 0000000000000000
Dec 12 05:41:27 kernel: x1 : 000000000007c674 x0 : 0000000000000000
Dec 12 05:55:15 kernel: pgd = ffffffc00994a000
Dec 12 05:55:15 kernel: [00000000] *pgd=00000000117f6003, *pud=00000000117f6003, *pmd=0000000015183003, *pte=0000000000000000
Dec 12 05:55:15 kernel: CPU: 1 PID: 14778 Comm: dcd Tainted: P O 4.1.27 #2
Dec 12 05:55:15 kernel: Hardware name: Broadcom-v8A (DT)
Dec 12 05:55:15 kernel: task: ffffffc0192dcac0 ti: ffffffc01221c000 task.ti: ffffffc01221c000
Dec 12 05:55:15 kernel: PC is at 0xf74f7f44
Dec 12 05:55:15 kernel: LR is at 0x1dc74
Dec 12 05:55:15 kernel: pc : [<00000000f74f7f44>] lr : [<000000000001dc74>] pstate: 60030010
Dec 12 05:55:15 kernel: sp : 00000000ffd3cc58
Dec 12 05:55:15 kernel: x12: 000000000009ff10
Dec 12 05:55:15 kernel: x11: 00000000f67ff024 x10: 00000000000a0766
Dec 12 05:55:15 kernel: x9 : 0000000000000028 x8 : 00000000000a076c
Dec 12 05:55:15 kernel: x7 : 0000000000000027 x6 : 00000000f67ffd5c
Dec 12 05:55:15 kernel: x5 : 0000000000000000 x4 : 00000000f67ffcf8
Dec 12 05:55:15 kernel: x3 : 0000000000000000 x2 : 0000000000000000
Dec 12 05:55:15 kernel: x1 : 000000000007c674 x0 : 0000000000000000
Dec 12 06:06:22 WLCEVENTD: eth6: Disassoc B0:72:BF:ED:D5:2F
Dec 12 06:25:22 kernel: pgd = ffffffc0117c8000
Dec 12 06:25:22 kernel: [00000000] *pgd=00000000143af003, *pud=00000000143af003, *pmd=000000000a65a003, *pte=0000000000000000
Dec 12 06:25:22 kernel: CPU: 1 PID: 15722 Comm: dcd Tainted: P O 4.1.27 #2
Dec 12 06:25:22 kernel: Hardware name: Broadcom-v8A (DT)
Dec 12 06:25:22 kernel: task: ffffffc01710cac0 ti: ffffffc012190000 task.ti: ffffffc012190000
Dec 12 06:25:22 kernel: PC is at 0xf72bbf44
Dec 12 06:25:22 kernel: LR is at 0x1dc74
Dec 12 06:25:22 kernel: pc : [<00000000f72bbf44>] lr : [<000000000001dc74>] pstate: 60030010
Dec 12 06:25:22 kernel: sp : 00000000ffb7bbc8
Dec 12 06:25:22 kernel: x12: 000000000009ff10
Dec 12 06:25:22 kernel: x11: 00000000f65ff024 x10: 00000000000a0766
Dec 12 06:25:22 kernel: x9 : 0000000000000028 x8 : 00000000000a076c
Dec 12 06:25:22 kernel: x7 : 0000000000000027 x6 : 00000000f65ffd5c
Dec 12 06:25:22 kernel: x5 : 0000000000000000 x4 : 00000000f65ffcf8
Dec 12 06:25:22 kernel: x3 : 0000000000000000 x2 : 0000000000000000
Dec 12 06:25:22 kernel: x1 : 000000000007c674 x0 : 0000000000000000
Dec 12 06:48:25 kernel: pgd = ffffffc0141c9000
Dec 12 06:48:25 kernel: [00000000] *pgd=00000000177aa003, *pud=00000000177aa003, *pmd=000000001302c003, *pte=0000000000000000
Dec 12 06:48:25 kernel: CPU: 1 PID: 17681 Comm: dcd Tainted: P O 4.1.27 #2
Dec 12 06:48:25 kernel: Hardware name: Broadcom-v8A (DT)
Dec 12 06:48:25 kernel: task: ffffffc019308b00 ti: ffffffc01221c000 task.ti: ffffffc01221c000
Dec 12 06:48:25 kernel: PC is at 0xf6fe9f44
Dec 12 06:48:25 kernel: LR is at 0x1dc74
Dec 12 06:48:25 kernel: pc : [<00000000f6fe9f44>] lr : [<000000000001dc74>] pstate: 60030010
Dec 12 06:48:25 kernel: sp : 00000000ffbd7c98
Dec 12 06:48:25 kernel: x12: 000000000009ff10
Dec 12 06:48:25 kernel: x11: 00000000f62ff024 x10: 00000000000a0766
Dec 12 06:48:25 kernel: x9 : 0000000000000028 x8 : 00000000000a076c
Dec 12 06:48:25 kernel: x7 : 0000000000000027 x6 : 00000000f62ffd5c
Dec 12 06:48:25 kernel: x5 : 0000000000000000 x4 : 00000000f62ffcf8
Dec 12 06:48:25 kernel: x3 : 0000000000000000 x2 : 0000000000000000
Dec 12 06:48:25 kernel: x1 : 000000000007c674 x0 : 0000000000000000
Dec 12 07:06:43 kernel: pgd = ffffffc0197d5000
Dec 12 07:06:43 kernel: [00000000] *pgd=0000000011c52003, *pud=0000000011c52003, *pmd=000000000a6af003, *pte=0000000000000000
Dec 12 07:06:43 kernel: CPU: 1 PID: 19189 Comm: dcd Tainted: P O 4.1.27 #2
Dec 12 07:06:43 kernel: Hardware name: Broadcom-v8A (DT)
Dec 12 07:06:43 kernel: task: ffffffc01710cac0 ti: ffffffc01238c000 task.ti: ffffffc01238c000
Dec 12 07:06:43 kernel: PC is at 0xf757cf44
Dec 12 07:06:43 kernel: LR is at 0x1dc74
Dec 12 07:06:43 kernel: pc : [<00000000f757cf44>] lr : [<000000000001dc74>] pstate: 60030010
Dec 12 07:06:43 kernel: sp : 00000000ffda6d38
Dec 12 07:06:43 kernel: x12: 000000000009ff10
Dec 12 07:06:43 kernel: x11: 00000000f68ff024 x10: 00000000000a0766
Dec 12 07:06:43 kernel: x9 : 0000000000000028 x8 : 00000000000a076c
Dec 12 07:06:43 kernel: x7 : 0000000000000027 x6 : 00000000f68ffd5c
Dec 12 07:06:43 kernel: x5 : 0000000000000000 x4 : 00000000f68ffcf8
Dec 12 07:06:43 kernel: x3 : 0000000000000000 x2 : 0000000000000000
Dec 12 07:06:43 kernel: x1 : 000000000007c674 x0 : 0000000000000000
You think yours is bad!!!
I have this today
20:51 kernel: x12: 000000000009ff10
Dec 12 04:20:51 kernel: x11: 00000000f66ff024 x10: 00000000000a0766
Dec 12 04:20:51 kernel: x9 : 0000000000000028 x8 : 00000000000a076c
Dec 12 04:20:51 kernel: x7 : 0000000000000027 x6 : 00000000f66ffd5c
Dec 12 04:20:51 kernel: x5 : 0000000000000000 x4 : 00000000f66ffcf8
Dec 12 04:20:51 kernel: x3 : 0000000000000000 x2 : 0000000000000000
Dec 12 04:20:51 kernel: x1 : 000000000007c674 x0 : 0000000000000000
Dec 12 04:23:29 WLCEVENTD: eth5: Disassoc D8:42:E2:09:AF:22
Dec 12 04:50:50 WLCEVENTD: eth5: Disassoc 84:20:96:FD:8C:9E
Dec 12 04:51:12 kernel: pgd = ffffffc012143000
Dec 12 04:51:12 kernel: [00000000] *pgd=000000001115e003, *pud=000000001115e003, *pmd=0000000014208003, *pte=0000000000000000
Dec 12 04:51:12 kernel: CPU: 1 PID: 9410 Comm: dcd Tainted: P O 4.1.27 #2
Dec 12 04:51:12 kernel: Hardware name: Broadcom-v8A (DT)
Dec 12 04:51:12 kernel: task: ffffffc0120e21c0 ti: ffffffc012230000 task.ti: ffffffc012230000
Dec 12 04:51:12 kernel: PC is at 0xf7500f44
Dec 12 04:51:12 kernel: LR is at 0x1dc74
Dec 12 04:51:12 kernel: pc : [<00000000f7500f44>] lr : [<000000000001dc74>] pstate: 60030010
Dec 12 04:51:12 kernel: sp : 00000000ff9095f8
Dec 12 04:51:12 kernel: x12: 000000000009ff10
Dec 12 04:51:12 kernel: x11: 00000000f67ff024 x10: 00000000000a0766
Dec 12 04:51:12 kernel: x9 : 0000000000000028 x8 : 00000000000a076c
Dec 12 04:51:12 kernel: x7 : 0000000000000027 x6 : 00000000f67ffd5c
Dec 12 04:51:12 kernel: x5 : 0000000000000000 x4 : 00000000f67ffcf8
Dec 12 04:51:12 kernel: x3 : 0000000000000000 x2 : 0000000000000000
Dec 12 04:51:12 kernel: x1 : 000000000007c674 x0 : 0000000000000000
Dec 12 04:57:46 kernel: pgd = ffffffc01921b000
Dec 12 04:57:46 kernel: [00000000] *pgd=0000000019181003, *pud=0000000019181003, *pmd=00000000150b9003, *pte=0000000000000000
Dec 12 04:57:46 kernel: CPU: 1 PID: 11368 Comm: dcd Tainted: P O 4.1.27 #2
Dec 12 04:57:46 kernel: Hardware name: Broadcom-v8A (DT)
Dec 12 04:57:46 kernel: task: ffffffc01707cbc0 ti: ffffffc0116bc000 task.ti: ffffffc0116bc000
Dec 12 04:57:47 kernel: PC is at 0xf75cff44
Dec 12 04:57:47 kernel: LR is at 0x1dc74
Dec 12 04:57:47 kernel: pc : [<00000000f75cff44>] lr : [<000000000001dc74>] pstate: 60030010
Dec 12 04:57:47 kernel: sp : 00000000ff814008
Dec 12 04:57:47 kernel: x12: 000000000009ff10
Dec 12 04:57:47 kernel: x11: 00000000f68ff024 x10: 00000000000a0766
Dec 12 04:57:47 kernel: x9 : 0000000000000028 x8 : 00000000000a076c
Dec 12 04:57:47 kernel: x7 : 0000000000000027 x6 : 00000000f68ffd5c
Dec 12 04:57:47 kernel: x5 : 0000000000000000 x4 : 00000000f68ffcf8
Dec 12 04:57:47 kernel: x3 : 0000000000000000 x2 : 0000000000000000
Dec 12 04:57:47 kernel: x1 : 000000000007c674 x0 : 0000000000000000
Dec 12 05:03:53 kernel: ^[[0;33;41mBLOG ERROR blog_request :blog_key corruption when deleting flowfor net_p=ffffffc016850010
Dec 12 05:03:53 kernel: ^[[0m
Dec 12 05:05:12 kernel: pgd = ffffffc0117f5000
Dec 12 05:05:12 kernel: [00000000] *pgd=00000000153ef003, *pud=00000000153ef003, *pmd=000000001502f003, *pte=0000000000000000
Dec 12 05:05:12 kernel: CPU: 1 PID: 11764 Comm: dcd Tainted: P O 4.1.27 #2
Dec 12 05:05:12 kernel: Hardware name: Broadcom-v8A (DT)
Dec 12 05:05:12 kernel: task: ffffffc00b0200c0 ti: ffffffc011728000 task.ti: ffffffc011728000
Dec 12 05:05:12 kernel: PC is at 0xf745cf44
Dec 12 05:05:12 kernel: LR is at 0x1dc74
Dec 12 05:05:12 kernel: pc : [<00000000f745cf44>] lr : [<000000000001dc74>] pstate: 60030010
Dec 12 05:05:12 kernel: sp : 00000000ffba91b8
Dec 12 05:05:12 kernel: x12: 000000000009ff10
Dec 12 05:05:12 kernel: x11: 00000000f66ff024 x10: 00000000000a0766
Dec 12 05:05:12 kernel: x9 : 0000000000000028 x8 : 00000000000a076c
Dec 12 05:05:12 kernel: x7 : 0000000000000027 x6 : 00000000f66ffd5c
Dec 12 05:05:12 kernel: x5 : 0000000000000000 x4 : 00000000f66ffcf8
Dec 12 05:05:12 kernel: x3 : 0000000000000000 x2 : 0000000000000000
Dec 12 05:05:12 kernel: x1 : 000000000007c674 x0 : 0000000000000000
Dec 12 05:10:32 kernel: pgd = ffffffc0121ae000
Dec 12 05:10:32 kernel: [00000000] *pgd=0000000012310003, *pud=0000000012310003, *pmd=0000000012288003, *pte=0000000000000000
Dec 12 05:10:32 kernel: CPU: 1 PID: 12410 Comm: dcd Tainted: P O 4.1.27 #2
Dec 12 05:10:32 kernel: Hardware name: Broadcom-v8A (DT)
Dec 12 05:10:32 kernel: task: ffffffc0192c0a40 ti: ffffffc01221c000 task.ti: ffffffc01221c000
Dec 12 05:10:32 kernel: PC is at 0xf731ef44
Dec 12 05:10:32 kernel: LR is at 0x1dc74
Dec 12 05:10:32 kernel: pc : [<00000000f731ef44>] lr : [<000000000001dc74>] pstate: 60030010
Dec 12 05:10:32 kernel: sp : 00000000ff891078
Dec 12 05:10:32 kernel: x12: 000000000009ff10
Dec 12 05:10:32 kernel: x11: 00000000f65ff024 x10: 00000000000a0766
Dec 12 05:10:32 kernel: x9 : 0000000000000028 x8 : 00000000000a076c
Dec 12 05:10:32 kernel: x7 : 0000000000000027 x6 : 00000000f65ffd5c
Dec 12 05:10:32 kernel: x5 : 0000000000000000 x4 : 00000000f65ffcf8
Dec 12 05:10:32 kernel: x3 : 0000000000000000 x2 : 0000000000000000
Dec 12 05:10:32 kernel: x1 : 000000000007c674 x0 : 0000000000000000
Dec 12 05:41:27 kernel: pgd = ffffffc0117cb000
Dec 12 05:41:27 kernel: [00000000] *pgd=000000000a648003, *pud=000000000a648003, *pmd=000000000b99f003, *pte=0000000000000000
Dec 12 05:41:27 kernel: CPU: 1 PID: 12940 Comm: dcd Tainted: P O 4.1.27 #2
Dec 12 05:41:27 kernel: Hardware name: Broadcom-v8A (DT)
Dec 12 05:41:27 kernel: task: ffffffc014136ac0 ti: ffffffc012044000 task.ti: ffffffc012044000
Dec 12 05:41:27 kernel: PC is at 0xf707ff44
Dec 12 05:41:27 kernel: LR is at 0x1dc74
Dec 12 05:41:27 kernel: pc : [<00000000f707ff44>] lr : [<000000000001dc74>] pstate: 60030010
Dec 12 05:41:27 kernel: sp : 00000000fff80d48
Dec 12 05:41:27 kernel: x12: 000000000009ff10
Dec 12 05:41:27 kernel: x11: 00000000f63ff024 x10: 00000000000a0766
Dec 12 05:41:27 kernel: x9 : 0000000000000028 x8 : 00000000000a076c
Dec 12 05:41:27 kernel: x7 : 0000000000000027 x6 : 00000000f63ffd5c
Dec 12 05:41:27 k
Since over 1 year they try to get the FW on an acceptable level without success. This is the worstest one. Even my SIP account is offline from time to time. Router reset every two days
agree.....many gui bugs like no scroll bar for clients on Adaptive Qos/Bandwidth monitor, client list is very not stable, not show all clients etc, AIProtection ocasionally stop working etc
Could you send feedback with system log, wifi log by Administration-> Feedback?
After many tests the problem of loss of IPv6 is if some of the devices that are connected to the network have an empty or not allowed hostname, in my case I have a samsung TV UN65JS8500 that has as hostname "localhost" and a tv sony KDL -55W800A that sometimes had an empty hostname
