Anyone know if with this firmware has implemented the triple vlan for movistar tv?
I wonder if it is common for 5GHz legacy client devices to support DFS channels.
OK folks. Someone with Trend Micro services enabled (Adaptive QoS or AIProtection) needs to please try this firmware and see if the "dcd" kernel fault error message is still happening, or if it's been resolved by Asus.
Please? Pretty please?
hmm..... my 86u is loosing 5GHz band. I have must rebot router to start 5GHz work ok for a few times and again gone
Switched from Merlin to Asus official 3.0.0.4.384_45713 and no issues at all so far, I like it.
Reset to factory default first, reboot......
Finally stable Network Map, so nice!
Well, I reset to factory first and then uploaded the new firmware, then rebooted, so complicated...
I usually get it wrong but it still works
Flashed over Merlin. No reset needed. Perfecto!
I have gone from Merlin to Asus back and forth a few times and never needed a reset.
I hope this fixed the issues with the 2.4 GHz channel. I have 3 asus routers. 2 86U's and one 3100. the 3100 and one of the 86's are running as a mesh node and the 3100 is always rock stable. For some reason though, my wireless devices connected to the 86U will always get disconnected and the only way to fix it is a hard reboot on the 86U mesh router....Hope this is fixed?
Yeh...been concerned that this was the issue. Bought my 86U's back when they first launched in 2017. Funny thing is that the 86U running as the main router has been running like a champ. I hope this firmware fixes the issue.If it doesn't, then I would suspect the 2.4 GHz radio hardware.
OE
Welcome To SNBForums
