My AiMesh: RT-AC86U Router (FW 32799)
Node#1 RT-AC68U (Wired Backhaul) (FW 32738)
Node #2 RT-AC66U_B1 (WIFI Backhaul) (FW 32738)
Was having general stability problems with 32797. My ROUTER (AC86U) would go offline every several days, fixed by reboot, so I updated to 32799 FW. I suspect my stability issues with 32797 had to do with the fact that I did not, as recommended, do a factory reset. So this time I did, on the router and both nodes. Since it was such a thrash, I decided to test performance while I was at it, to investigate
@OzarkEdge's reports. I observed:
The wired backhaul reports a transmission rate of 702 Mbps, which seems consistent with my gigabit service.
My speed tests give me ~300Mpbs, which I expect, given that I have QoS implemented.
The wireless backhaul reports a transmission rate of 867 Mbps, but my speed tests only give me ~140 Mbps.
This is about half the speed, at the WIFI backhaul. Additionally, my bufferbloat drops from a B to a C. A wired connection at the WIFI backhaul gives me the expected ~300Mbps, and my expected WIFI bufferbloat score of B.
Other observations: the download speed is affected, not the upload speed, which remains steady whether I'm connected to router, wired or wireless node, using WIFI or LAN connection.
I think this is a firmware issue. For my part, since I have high speeds, I'm keeping the current firmware (switching it out is not for the faint of heart!). I'll report on stability if I have issues. I'm hoping I won't!
