Yeap, exactly the same. NTP and "non-work-conserving" presumably from the USB HD attached (?).Nothing but NTP updates and occasional "non-work-conserving" messages in the log.
I think it's a result of QoS (qdisc = "queuing discipline") but I admit I'm not 100% sure. If it is I'm still not sure why it appears in the log, but it doesn't seem to be a bad thing!....."non-work-conserving" presumably from the USB HD attached (?).
Ditto here. Router and AP, both on 4950 have now been up for 10 days.
20 devices flawlessly roaming between AP and Router, 2.4 and 5Ghz (5Ghz beamforming still has to be off).
I dont know if reset is necessary. I install 4950 in 2015.04.02 , without reset and so far so good, everything Works fine.Normally I'm a great believer in "if it ain't broke.... don't fix it", but 4950 is a great step up from 4608.
You obviously were unlucky with resetting your router - I had a similar problem initially. Follow the instructions for resetting NVRAM carefully. It can be worth resetting several times (and maybe even using different methods) to be sure! Reset - Upgrade - Reset - Load from scratch (not using saved settings). If you have a problem even after this, try reinstalling 4950 onto a router which already HAS 4950 and is already reset to factory defaults! This finally fixed a weird issue for me. Someone may jump in and say I'm overcomplicating things and that there IS a simple 100% effective way to upgrade without issue, but as someone who had 2 AC87Us that both upgraded into a strange state, despite multiple resets, I do think this router has issues with being properly reset, but I would say 4950 is worth it!
One iPad that stays in the same room most of the time, so rarely has to roam has been connected non-stop to the same 5Ghz radio for 5 days nowDitto here. Router and AP, both on 4950 have now been up for 10 days.
It is fixed in the new Beta. Er, I think?I see Asus still haven't the bug in fw 4950 where the LEDs don't remain switched off permanently despite switching them off via the hard button. This happens quite often after a reboot or when changing some config setting. Will Asus EVER fix this bug?
Dear all,
RT-AC87U: 3.0.0.4_378_5134 Unofficial beta
Changelog:
Update: QIS ver. 1.5
Update: traffic monitor
Fix: reduce media server memory usage
Fix: [Media Bridge] Can't connect to P-AP by 5GHz DFS channel
Fix: [USB Application][Media Server - Windows media player
Fix: WAN Status LED
* No hard reset require from build 4950
Download: http://goo.gl/ppJuct
Best regard,
JK
Welcome To SNBForums
