Hello,
I would like to ask if someone know what is the difference between sus RT-AX53U and Asus RT-AX1800U models? Because there is a slight price difference between these models.
I already asked asus, but didn't get a proper answer. They just sent me link of both models "tech spec". Only difference in "Tech spec" is that RT-AX53U processor is Dual-core (4 VPE) and RT-AX1800U processor is Dual-core.
And also I asked Asus about "Smart connect", but they told that these routers don't support such function, but I found such information in firmware version 3.0.0.4.386.68691 - "improved smart connect function." I would like to buy 2 wifi 6 routers and make mesh using ethernet backhaul, but don't want to have 2 different 2.4Ghz and 5Ghz wifi SSID.
Thank you in advance.
RT-AX53U、RT-AX1800U Product different Compare|ASUS Global
Comparison between RT-AX53UãRT-AX1800U in Network Standard ãProduct Segment ãWiFi Data Rate ãAntenna ãTransmit / Receive ãProcessor ãMemory ãBoosts SpeedãOperating Frequency ãOperating ModeãI/O Ports ãButtonsãLED Indicator ãPower Supply ãPackage Content ãProduct Weight (g)ãProduct...
www.asus.com
