Today I received an Asus RT-AX56U router and am testing the parental controls. I tried the router on standard firmware and had issues with the parental controls so updated to the Merlin FW V388.1
I'm testing with my windows desktop attached via ethernet. I'm finding the parental controls time blocking works for web pages and most apps. But the Roblox game app will not stop at the set off time and will just keep going. After searching I found posts saying to turn off NAT acceleration but it seems this router doesn't have that setting in the GUI.
I've made sure the time is set correctly, I'm seeing the block icon on the device page of the router next to my PC details when the off time starts. The same thing happens when I block the computer, Roblox keeps going. The only thing that works is the block all computers switch.
I've done a factory reset after applying the Merlin firmware and it has made no difference.
Any ideas? I've tested older routers of other brands and they do the same thing, hence the reason for buying the Asus. I had high hopes for the Asus, I'm hoping its something that can be fixed.
