Beta ASUS RT-AX88U Version 9.0.0.4.388.20477 (2022/08/02)
  • Thread starter Thread starter Deleted member 80734
  • Start date Start date
Sorry, where is the WireGuard NAT option?
I’m not familiar with that one.
It's this toggle switch in the wireguard profile.
Pretty happy with this 388.x beta firmware.
All I need now is for Asus to increase the number of concurrent VPN connections to 3, and I will buy a tri-band router to continue testing.
I‘m afraid my old RT-AC3200 is not up to the job.
ASUS RT-AX88U Firmware version 9.0.0.4.388.20477
1. Supported WireGuard VPN server and client.
2. Supported VPN fusion. It can easily achieve VPN connection to network devices like Smart TV, Game consoles and without installing the VPN client software.
3. Support HMA VPN in VPN fusion to securely and quickly access streaming sites from over 190+ countries
4. Supported new devices connection notification.
5. Supported connection diagnostic on the ASUS router app.
6. Supported Instant Guard 2.0 which helps easily invite family or friends to join the VPN connection.
7. Upgraded parental control and added reward, new scheduler for flexible setting
Please unzip the firmware file first then check the MD5 code.
MD5: 9e6b286cd3c5841f3bfbb443210c4ded
Asus Website
Download
After updated this firmare, the internet speed dropped from 920Mbps to 740! Any reason?
Why did you update to the beta? You have a stable firmware release available:
How can I allow peers to talk to each other? I can ping server to peer and peer to server but I can't ping peer to peer.
