Updated to this version this morning and after 8 hours rolled back to .270. New firmware indeed showing better WIFI performance, but also periodically dropping connection, as was in pre-.270 builds.
Actually it was not exactly a "disconnect", it was more like WIFI restarts. Sometimes, without any reason, all computer connected to WIFI (2.4 and 5) suddenly stop delivering any data (WIFI indicator on PC is showing that connection is still alive) but another wired PC is OK and can access the web. After 1-2 minutes connection is dropped (for all WIFI connected devices in the same time) and then reconnects again after 10-15 seconds. In 8 hours it happened to me 3 or 4 times. I verified logs but nothing found in it, everything was as usual. Maybe it depends on environment and number devices connected... Will wait for next build...Interesting, I upgraded to this firmware yesterday, and it's been fine. No disconnects or dropped connections.
The correct version 3.0.0.4.354 is now posted in the official site.As like what likstone87 have said, all these are managed @ ASUS HQ ~ Taiwan
The correct version 3.0.0.4.354 is now posted in the official site.![]()
Beta Version 3.0.0.4.354 ???
No, it's the one that is supposed to be released but they posted the wrong one 5.354.that has dual wan beta.
Yes I know that, but the site (Asus -> support -> download) says beta
Ah, now I see what you mean, earlier the download wasn't tag as a beta. Oh well, it just shows Asus QA is not at their best.It's ok probably in two days Merlin's 354 quality release will be ready anyway.
Don't expect anything until the weekend at the earliest.
Is the "Optimize for XBOX option in Advanced Setting" in beta firmware 3.0.0.4.354 on Asus' official site only for a wireless connection and not for a wired connect?
I believe the answer is yes since the option is in the wireless section. I don't have xbox so you might wait for other opinions.
Thanks Bluepoint.
I wonder if this could cause issues with other Wireless devices and that's why its got a tick box so it can be disabled rather than just been enabled all the time.
Plus from what I see, still no source code released. So Merlin gonna be waiting on that, and seeing as this is now consider a "beta" release. Hopefully they will release the source code, as this isn't the first beta asus has posted, and they did release the source code to it.Ah, now I see what you mean, earlier the download wasn't tag as a beta. Oh well, it just shows Asus QA is not at their best.It's ok probably in two days Merlin's 354 quality release will be ready anyway.
Welcome To SNBForums
