Hello!
I'm planning to buy ASUS RT-N66U this month and have a few questions:
1. What is the max. hdd size (and partition size) that you can connect through USB port?
2. What is the maximum filesize that router can read/write on hdd?
3. What transfer rate (read/write) can I expect for USB hdd -> LAN file transfers (wired & wireless)?
4. I read that power adapter works on 19V and max. power is 1.58A..that is 30W per hour. So what is the actual measured power consumption of router?
Can only answer #4, its about 8-9watts. That's how much the load increased on my UPS.
Hello!
1. 3TB HDD installed here, working fine.
2. It depends on the filesystem, ext3,ext4 or ntfs.
3. 15-18mb/s (wired), wireless it depends the speed you are connected.
4. Measured with a machine. 8-9W ~ Idle. CPU Full 10-11W.
I really dont consider it so "low power consumption" a ATOM system does the same and it has alot more powerhorse.
If you read on this forum .106 is a minor update, nothing will change from .102 to .106, unless a problem when updating from .84 to .102.
Great, thanks hggomes! I was asking about max. hhd & filesize becouse of that spreadsheet http://event.asus.com/2009/networks/disksupport/
RT-N56U supports max. 2TB hdd and 8GB filesize, but unfortunately RT-N66U is not listed there.
Can you read/write a file bigger than 8GB on a hdd (ntfs) connected to RT-N66U?
hi all!
on firmware .102 port forwarding is working correctly?
thanks
I'm looking for 106 on the Asus page ( I believe one of the comments on this forum from a Asus rep said to expect 106 today, Thursday). Anybody notice what time of day Asus normally posts their firmware updates?
Also anybody ever successfully downloaded and applied an N66U firmware update using Mac OS X Lion yet?
for me is not working
you set it in virtual server section?
for me is working partially, there is a bug / limit i think
Thread starter | Title | Forum | Replies | Date |
D | Asus RT-AC86U Dual Wan and IPV6 | ASUS N Routers & Adapters | 8 | |
B | Issue with wired clients on ASUS N56U | ASUS N Routers & Adapters | 0 | |
J | I can't reset or access ASUS TUF-AX6000 GUI | ASUS N Routers & Adapters | 8 |
Welcome To SNBForums
