sm00thpapa
It works for me. Did you do a factory re-set after installing the firmware?
I did a hard reboot as requested, but not a factory reset. I really don't want to recreate my settings again.
It does work well here, also after upgrading to 3.0.0.4.376.1071 without a hard reset.I recently upgraded the firmware to 3.0.0.4.376_1071. Now the parental controls do not work. When I click on enable parental control, a table row that says system time displays, but that's it -- no save or apply or any of the other configuration items I expected. Any ideas?
Thanks,
Brian
Same here. Ever since Asus went to the SDK6 driver the wireless went bad on the RT-N66U.
Is the merlin 374.35_4 sdk5 build worth trying on the rt-n66u?
Yes, some have used it and still using it and say the range is very good and stable.
Just flash it via the GUI and it will be fine. I done it many times.sounds cool. I might give it a try pretty soon.
Are there any known bugs or security issues with that particular firmware model?
It would probably be best to upload it through the firmware recovery mode right?
I just re set to factory specs and reconfigure it. All accomplish the same thing and clear the NVRAM....and is clearing the nvram by the wps button method the same as using telnet or through the asus cfe page?
Welcome To SNBForums
