Asus RT-N66u with TomatoUSB firmware
With the 220 driver in build 104 and CTF enabled this build seems the same as stock for wireless speed so far in testing.
Anyone else have similar results?
This is interesting to me so i may upgrade to 104. What is CTF? (I have "Capture the FLag" on my mind. :) )
How do you flash 64k cfe? Is there a link somewhere to that?
There's a whole thread dedicated to it here in this forum.
Hi folks just bought this router on Monday. I just stepped away from a long series of Linksys routers of which the 54 series was still the best.
Now since I am used to Tomato I tried the latest Shibby on mine.
What I found weird is that the 2.4GHz link seemed to be extreemly slow in a place where the Merlin image would still be getting ok'ish speeds.
Now I placed the laptop with the Intel 6300 card right next to the router and I see the speed jump like crazy.
Now I tried changing the power settings, even to 10mW but on inssider it doesn't seem to change the signal strenght at all.
Anything that is broken in this build or is it working on your router?
When you were running Tomato...did you enable CTF?
Does that enable you to alter the power settings?
I also had the link speed jumping like crazy on 2.4GHz while I was standing right next to the router. Going from 200mbps to 16mbps etc
Can anyone tell me if the 3G Ovation MC760 USB dongle is supported in shibby build. If not.. how would one go about getting it added
Sorry for the off-topic, but can somebody tell us if is there any chance for TomatoUSB to also support Asus RT-AC66u? I really miss the TomatoUSB features...
Thanks!
Steps to setup a block of Static IP on RT-N66U router using Shibby build...
A quick note for users who are looking for a way to setup a block of static IP on their ASUS RT-N66U router (you will be using Shibby's build):
1. Download Shibby's TomatoUSB firmware "tomato-K26USB-1.28.RT-N5x-MIPSR2-104-AIO-64K.trx" (google that filename for download link)
2. Set your computer's ip (make it static) between 192.168.1.2 and 192.168.1.254 (ASUS RT-N66U router defaults to having 192.168.1.1 in "rescue mode").
3. Disconnect all ethernet cables from RT-N66U router and turn it off
4. Connect an ethernet cable between your computer and one of RT-N66U LAN ports (pick any yellow colored port between 1 ~ 4, do NOT connect to WAN port which is blue and labelled "e")
5. Press "Reset" button and keep it pressed, and then turn ON the power to RT-N66U router
6. Wait for 10 seconds or so and make sure that power LED light very slowly starts blinking - now you're in "rescue mode"
7. On your computer web-browser go to address "http://192.168.1.1"
8. You will see an option to upload new firmware to the router on that page, along with an option to Erase NVRAM. Click on the button for erasing NVRAM (I did it twice just to make sure)
9. Once NVRAM is erased in above step, select the Shibby build firmware file (the one you downloaded in step#1) and click on the button to upload it to the router. It will be quick to upload but you'll have to wait at least 90~120 seconds before the router programs properly and reboots.
10. Do NOT disturb the router while step #9 is in progress. Once 90 seconds pass, on your web-browser type "http://192.168.1.1" again. You will see Shibby build main page come up from the router.
11. I setup my router with one of the static IP (under "Basic" setup menu) from my AT&T assigned block of static IP's (in the block they assign you, I believe the first IP is public IP for broadcast, next 5 IP are usable by you, and the last IP is used as gateway IP. You can leave the router for DHCP configuration which is its default in Shibby build)
12. Go to menu "Administration->JFFS", and enable JFFS+format that partition (it's all done within that same page, it will take a few seconds to do so).
13. Once step#12 is done, turn off your router and disconnect the ethernet between your computer and the router
14. Temporarily connect an ethernet cable from your computer straight to LAN port of your AT&T router, go to its setup page (I access my AT&T router through "192.168.1.254", usually it's stated in your service provider or dsl/modem router manual). Setup your AT&T router for "IP-PASSTHROUGH" (under Firewall). Once done with that, disconnect the ethernet cable from it.
15. Connect an ethernet cable between one of the LAN ports of AT&T router and WAN (blue) port of ASUS RT-N66U router. Also connect another ethernet cable between LAN port (yellow) of RT-N66U router and your computer such that your setup has the following Router-behind-router (where AT&T router is in bridge mode) network wiring:
Internet<-->AT&T Router<-->RT-N66U<-->LAN (your computer)
16. On your computer, set the networking back to DHCP instead of static IP that you did in step#2.
17. Turn ON RT-N66U (assumption is that your AT&T router is already ON, if not then turn it ON first and wait for 90 seconds before turning ON RT-N66U router).
18. Wait for 90 seconds after you turned ON RT-N66U router in the above step.
19. Check network properties in your computer to get a new dynamically assigned IP address (it is now assigned dynamically by DHCP server in RT-N66U router). Replace the last digit on that IP address with a "1" and enter that address on your web-browser to access RT-N66U. (NOTE:: My computer gets assigned a dynamic IP address in range 192.168.2.2~254, in which case my RT-N66U is on 192.168.2.1 - this setting is all dependent upon what you have in AT&T router settings).
20. Go to "Administration->Scripts->Firewall" and enter the follow three lines for each static IP that you want to setup (don't forget to click on Save afterwards):
/usr/sbin/ip addr add 99.XXX.XXX.105/30 dev vlan1
/usr/sbin/iptables -t nat -I PREROUTING -d 99.XXX.XXX.105 -j DNAT --to-destination 192.168.2.20
/usr/sbin/iptables -t nat -I POSTROUTING 1 -p all -s 192.168.2.20 -j SNAT --to 99.XXX.XXX.105
Where 99.XXX.XXX.105 = one of the static IP addressese from the block of 5 static IP assigned by AT&T, and 192.168.2.20 = LAN IP of my computer to which I wanted the traffic routed. I then repeated above three lines for three more static IP's and left one free (assigned to RT-N66U router so that all other computers can go through that).
21. Final step is a reboot... you should be now setup with your block of static IP, with each of them getting routed to whichever computer you assigned in the above step.
This looks like a long process but hopefully simple and if you follow it properly then it won't take you more than 15~20 minutes to setup your network.
Good luck!
(Please feel free to correct me if you see any mistake(s) in my steps. I've tried to be as detailed and accurate as possible).
So there is absolutely no one on this forum to tell me if this works, testing with for example nssider or so ?
Yes, I know it would take like 5min time to do so, sighhh
toastman
Hi, Merry Christmas!
Which build fits for rt n66u?
tomato-E1200v2USB-NVRAM64K-1.28.0501MIPSR2Toastman-RT-N-VLAN-VPN?
victek is back
http://victek.is-a-geek.com/9013.html
victek wrote:
English, Next January 1, 2013 (CET) I'll release Tomato RAF 1.28.9013. Several important changes and new features are included. Beta version 9012 has been tested over 4 months and all bugs detected has been corrected for the definitive release in coincidence with year 2013.Download it
Turn off LEDS
Shibby posted this on the TomatoUSB forum:
et robowr 0x00 0x18 0x1e0
et robowr 0x00 0x1a 0x1e0
wl -i eth1 leddc 0
wl -i eth2 leddc 0
those commands should disabled LAN, WAN and wireless leds
If you want turn on all leds, then run:
et robowr 0x00 0x18 0x1ff
et robowr 0x00 0x1a 0x1ff
wl -i eth1 leddc 1
wl -i eth2 leddc 1
What kind of wireless performance is everyone getting from Tomato?
On stock Asus firmware, it's possible for me to get ~216Mbps transfer speeds over wireless. On Tomato, I'm lucky to get 120Mbps as a maximum. Wireless performance is fairly important to me so I'm using stock firmware until I can find the time to try to optimize the wireless settings in Tomato.
Is it common to see performance drops this significant? Or have I just not invested the time to squeeze the performance out of Tomato?
This was with Shibby's v104, by the way.
I don't believe the Connection Speed reported by a wireless client means all that much. What is your actual throughput under each firmware? That's the important thing.
