Bill_Stewart
Configuration
I have an ASUS RT-ACRH13 router (latest firmware as I write this: 3.0.0.4.380_8228) and DSL service (CenturyLink, PPPoE). The DSL modem is configured in "transparent bridge" mode (no NAT, PPPoE, etc.); the ASUS device is configured to connect with PPPoE and all of that works fine.
In order to reach the DSL modem's configuration page, I added a small NAT device ("router") in between the ASUS device and the DSL modem and configured a static route in the ASUS device to make the DSL modem's configuration page reachable. It looks like this:
The static route in the ASUS device is as follows:
Problem
From a device that is joined to the WiFi network (192.168.50.0/24), I am able to ping 192.168.0.1, but I cannot telnet to 192.168.0.1 or go to http://192.168.0.1. http and telnet fail when performed from a device on the 192.168.50.0/24 network.
This same configuration (static route) works without problems if I use an older Linksys router device.
I have worked around this for now by adding a static route on my computer directly instead of using the route in the ASUS device.
Question
Has anyone else run into any problems with static routes on an ASUS device? It seems odd that I can ping but not anything else--it's almost as if if ICMP works, but TCP does not.
Or have I discovered an obscure bug in the ASUS firmware?
LAN LAN WAN LAN
[ASUS]-------------------------[NAT]-----------------------[DSL]
192.168.50.1 192.168.50.2 192.168.0.2 192.168.0.1
Network/Host IP Netmask Gateway Metric Interface
192.168.0.0 255.255.255.0 192.168.50.2 2 LAN
Problem
Question
