pc-canada
Best Buy in the US
Here you go, some actual benchmarks, on a GT-AX6000.
Checked since it was shared they were at BestBuy US, the three closest BB's to me, and all have stockThis increases the chances of getting Asuswrt-Merlin support, but still RMerlin will have the final say.
Why is the design weird? Why would a switch be needed pre-router (which also wouldn’t work since a switch has no routing capabilities)?
What is that drive attached to?
The router has TWO 10 GbE ports, don’t forget that. The vast majority of ISP-provided gateways don’t have more than one 5 GbE port and the rest are 1 GbE ports. Most computers only come with 1 GbE ports, no multigig ports.Because there's no way to route multi gig output to other PC's from ISP provided 10G Gateway. Built in switch is port bottlenecked to 2.5/1G.
You could likely use the SFP port as a 2nd 10G, but it's pretty redundant and adds cost.
One argument would be to use the SFP for a fiber module, but many US based providers pass through gateways that have to authenticate service. (Or the backend from ISP is literally tied into the unit itself..)
I was only using a SanDisk flash drive...Just throwing things across...
SSD directly attach - WD NVME...
What do you expect when you're limited to Gigabit Ethernet?And one last one - Synology NAS over ethernet...
Keep in mind that in some countries you just have an Ethernet jack and get whatever speed the ISP switch/router in the basement/attic of your building offers. So some people actually have a 10 Gbps port in their homes and no other hardware is needed to get online.The router has TWO 10 GbE ports, don’t forget that. The vast majority of ISP-provided gateways don’t have more than one 5 GbE port and the rest are 1 GbE ports. Most computers only come with 1 GbE ports, no multigig ports.
Most ISP’s don't provide more than 1.2 or 2 Gbps, barely multigig. That’s why most routers and gateways won’t provide Ethernet past 2.5 GbE for years yet.
You would need to use a 10 GbE switch connected to one of the 10 GbE ports on the router to get more than 2.5 GbE to any other devices. ISP-provided gateways don’t have that capability.
I’m responding to the scenario proposed by Jasz. And in the US, most homes that have Ethernet-wiring only have 1 Gbps, not 10 Gbps. 10 GbE is not very wide-spread residentially in the US, Canada, Europe, or Asia, nor is 2.5 GbE.Keep in mind that in some countries you just have an Ethernet jack and get whatever speed the ISP switch/router in the basement/attic of your building offers. So some people actually have a 10 Gbps port in their homes and no other hardware is needed to get online.
There are also a lot of countries that rely on ONTs which converts the fibre to copper in the home, which also gives you a copper Ethernet port with no extra hardware needed.
As such, your suggested scenarios only applies to some people.
In Texas for example (where I live), newest homes only come with 1 GbE prewired, and customers have to request it; none have 2,5 or 10 GbE wired in the house. California is the only state that has 2.5 GbE prewired in latest new homes as standard.
Actually, CAT 5e is part of the NBASE-T spec up to 2.5 Gbps and that's largely why we ended up with 2.5 Ethernet to start with, as it allows older infrastructure to support higher speeds. It was supposed to be good enough for 5 Gbps as well, but it seems like CAT 6 is recommended for 5 Gbps now.CAT5E can support over 1G, just not officially. ANSI/TIA 568 CAT spec is "bare min" @ 328FT between E2E termination. Not all cables are created equal.
A solid core 5E copper cable @ 24AWG should have no problems for 2.5G. The issue is not knowing what the builder is using. I rather have a solid core 24AWG 5E over some CAT6 28AWG "2.D" spec UTP cable rated for in wall.
Most modern CAT5E cables outclass min CAT6 spec in frequency (250mhz), but the problem will be AWG and cheaper stranded designs.
CAT6 UTP is 10G capable in shorter runs. 6A would be spec shielded, which will help with general EMI, but not needed in every scenario.
Marketed has been flooded with 2.5G Realtek and intel ethernet chips since 2019.. at least on the build your own PC end.
Actually, CAT 5e is part of the NBASE-T spec up to 2.5 Gbps and that's largely we ended up with 2.5 Ethernet to start with, as it allows older infrastructure to support higher speeds. It was supposed to be good enough for 5 Gbps as well, but it seems like CAT 6 is recommended for 5 Gbps now.
Crap cables are always going to be crap cables.
I even managed to run 10 Gbps over CAT 5e for several months, I didn't even notice I had used the wrong cable, but that was a 1 meter run so...
We should see an increase of 5 Gbps Ethernet chips from Realtek this year, some motherboards already ship with them. They were announced last year at Computex and are a lot cheaper than Marvell's options. There will be a USB version as well. Runs cool to the touch.
I highly doubt these speeds are coming from any router's usb port.
Port limit is around 9.2-9.4gbps, though most ISP's have settled on 8 gig for overhead.
If a 1.3ghz InterAptiv MIPS design can do 8 gig with acceleration, I'm pretty sure a 2.6ghz A53 is fine.
You have to select firmware options compatible with NAT acceleration always. The previous generation 2.0GHz CPUs couldn't do even Gigabit without NAT acceleration. For true 10Gbps packet processing capabilities some fast x86 CPU is needed with multicore processes. Something Asuswrt doesn't have.
just referring to whatever the BCM4916 is.. "2.6ghz".A53 doesn't scale to 2.6GHz unfortunately...
MIPS is a dead architecture, they've moved over to RISC-V
It's starting to look like the serious designs will be similar to Cortex-A73 or similar
Welcome To SNBForums
