Release ASUS ZenWiFi AX (XT8) Firmware version 3.0.0.4.388.22068
Thanks for this. Man that's a lot of technical adjustments. Mine is pretty much stock. I don't need anything special. Currently running my old router. When I try this again I'll start playing with some of these settings.
One thing I did find just recently. I enabled Parental Controls - Web & Apps Filters to try and protect my grandson. within 8 hours the router crashed. Rebooted it and again it crashed. I disabled Parental Controls - Web & Apps Filters and it has been rock solid for over a week now. At first I thought it was the Parental Controls - Time Scheduling that was causing the crash but that's been enabled on 3 devices and working flawlessly.
My XT8 is great for 2 weeks.. then the remote node starts losing signal and dropping out. If I place it beside the router node, it still has a weak signal. This is fresh out of the box flashed to 22068.
This now happened again at week 4 of owning it. annoying. I flashed the remote to 21099 and I guess I will see how that works.
So far this combination has been rock solid.
Had nothing but trouble with 3.0.0.4.388.21617 and 3.0.0.4.388.22068.
Finally did this:
  • kept main router at 22068
  • downgraded other node to 21099
Last 24 hours have been seemingly stable.
Would speculate they introduced regression with 21617 _on repeaters_
I did try other node on 21101 but that didn't work out too well
thank you very much s_vald,
I'm also using mesh with 2 nodes. The Backhaul Connection is wireless and with the latest updates it was very unstable, the second node was non stop blue led blinking and in the syslog were many messages :
  • BHC: WiFi connection status change
  • BHC: Disconnected from CAP
  • MISC: wifi upstream is connected, and disconnected from CAP.
I've tried everything, even liming the the bandwidth of 5Ghz-2 to 20Mhz and probing every channel from 100 to 140, but with no luck.
So after i've read your post i've did the same:
  • kept main node at 3.0.0.4.388_22068
  • downgraded second node to 3.0.0.4.388_21099
I didn't reset anything and I've set BHC back to optimal - the bandwidth of 5Ghz-2 is 160Mhz with auto channel.
Now the BHC is stable and there are no more strange massages in the syslog.
update:
Unfortunately using this combination (main-22068, node-21099) I've had issues again - once per week the mesh disconnects and the second node just hangs (blinking blue light and no messages in the syslog). I've downgraded the second node to 386_49873, but the situation was the same.
I've switched to ASUSWRT-Merlin as the firmware on the second node and I was back to the old well known issue - sometimes the node changes the BHC from 5Ghz to 2.4Ghz and stays with it.
I've finally changed the country to #a on this node using a script from francoism90 and executing it on init-start.
My current configuration is:
  • main node is Asuswrt 3.0.0.4.388_22068
  • second node is asuswrt-merlin.ng 3.0.0.4.386.07_2-gnuton1 with
    • regrev=0
    • ccode=#a
    • country_code=#a
    • reg_mode=off
After a month of using it I've no issues - the BHC is using only 5Ghz-2 with 160Mhz without a single drop, so I'll probably stay with this versions and settings for a long time.
