ASUS Sufferer
Woke up and the node is yellow
Sad. Seems I'll need to wait for the next firmware update
If I were you I would just revert back to firmware version: 3.0.0.4.386_48706Woke up and the node is yellow
Thankyou! I don't actually know what I've done but currently with smart connect on and 3 nodes, all at latest, it's working fineIf I were you I would just revert back to firmware version: 3.0.0.4.386_48706
18 day's rock solid without any backhaul issues. I'm completely done and lost confidence with the Asus firmware updates.
I will stay at 48706 for now, despite the security fixes within the new builds.
My experience was Yellow at Node after I applied latest firmware (version same as this post subject) through the Asus Router App. So far for past 10 days my connection is now normal white. Here's how,Woke up and the node is yellow
- update latest firmware through Asus App. If the Node is not detectable by the App, I guess need to redo setup via App before you apply latest firmware
- via App, apply Factory Reset. (Yes need to re setup the name, password etc)
- During new setup, select DHCP, select split bands (2.4G, 5G-1, 5G-2)
- Select Backhaul "5G-2 first"
- Connect all devices to 5G-1 (some devices eg. my Sonos speaker cannot find 5G so I connected 2.4G was fine)
My router to node is 20m apart only same level. Works for me hope it works for you.
I would not dare to update if everything is working fine right now. There is a fair chance that an update will break a stable backhaul. I’m completely cured when it comes to Asus firmware updates and (despite the security fixes and new features) will stay on 3.0.0.4.386_48706, which provides me a rock solid backhaul connection.So I have been running 3.0.0.4.386_46061 since installation of my mesh have a wired backhaul used for home streaming, gaming, etc.
it seems i have no issues and is stable. only had to reset the remote node once in several months.
should i just continue with current firmware or should I update?
Forgot to post this last snap, make sure you go to the ai mesh and see that backhaul is dedicated and select the preferred AP is selected. As in my case, all three should be going direct to the GT-AX11000ProI finally have a stable and super fast Wifi setup, I kept running into backhaul issues but it seems it was due to mixing RT-AX86U with RT-AX58U for mesh. First off the Rt-AX86U firmware is horrible, memory issues, crashing etc. I went all new hardware. Main router/wifi GT-AX11000Pro 3.0.0.4.388_23556-gfef4962, mesh unites 2 - XT8 v2 hardware 3.0.0.4.388_23285-g5068da5 and 1 RT-AX92u 3.0.0.4.388_23630-g9d6ee22. 5gh-2 backhaul dedicated. I have the GT-AX11000Pro connected 2.5Gb to my Xfinity gateway with 1.4Gb down and 40Mb up, 16ms pings. It's been running two weeks and not a single family member yelling at me due to Internet slow or game lag. I have a 4,500 Square foot home the setup covers basement, main and upstairs. I have 45 devices connected between wired and wireless all the time. Sure the setup was a bit pricy, I was able to get the dual XT-8 v2 hardware on Amazon because I ordered it in white and got v1, sent it back ordered the XT8 dual in black and it's v2 hardware. My RT-AX92u is old but works great now that I have the dedicated 5Ghz-2 backhaul. I am not going to update my firmware unless I am having an issueI hope this helps someone.
View attachment 51930View attachment 51931
View attachment 51932View attachment 51933View attachment 51934
A bit of a newbie question but where can I downgrade the firmware from? I've got major issues with my four units. CheersIf I were you I would just revert back to firmware version: 3.0.0.4.386_48706
Do you want the original or the custom firmware https://github.com/gnuton/asuswrt-merlin.ng/releases/tag/388.2_2_0-gnuton1 and choose the right firmware for your routers.A bit of a newbie question but where can I downgrade the firmware from? I've got major issues with my four units. Cheers
I did read your post above and might give that a go if this original 3.0.0.4.386_48706 one doesn't make a difference. I take it the downgrade option is somewhere in the browser version but haven't spotted it so far.Do you want the original or the custom firmware https://github.com/gnuton/asuswrt-merlin.ng/releases/tag/388.2_2_0-gnuton1 and choose the right firmware for your routers.
I would very much like to learn from your experience, so if you wouldn't mind sharing your settings please do soI would definitely not update if everything is working fine. Unless you need more excitement in your life. I've found the XT8's to be pretty fragile in operation with very poor quality control of firmware updates. And their tech support is completely useless.
I have managed to achieve totally stable operation for 58 days so far with the 3.0.0.4.388_23285 firmware. But that's after much tinkering with configuration settings and making backhaul performance compromises. Happy to share my settings if anybody is interested. But there's no guarantee that they would work in your environment.
Are you using the 5Ghz-2 channel for backhaul? Also, are all 4 units XT8 or are you mixing Asus routers?I would very much like to learn from your experience, so if you wouldn't mind sharing your settings please do so![]()
Welcome To SNBForums
