No need to apologize.
As long as we can understand the full story, I think we can better appreciate the 'extras' that certain companies do for their customers.
Some may still think that it is built into the price. But there are many other benefits of owning an Asus router that outweigh even the few negatives about them. Compared to other consumer router manufacturers, Asus is head and shoulders above them when all important areas are equally compared and weighed.
Hi everyone,
I don't know if I'm alone with this, but I still experience issue with asus ddns. I'm monitoring my line on the Dslreports web site and since the asus ddns is back online it's register my new ip address (I have reboot my router since then) but sometimes it reverts back to my old ip address before the down time. So my monitoring is on and off with my asus ddns name but everything is fine if I enter directly my ip address.
There is no hint in the router log.
If I check my ip with the iplookup tool on the router ddns page it shows my actual ip address, but a moment later my old one. It's done the same if I ping my ddns on my terminal.
I have reboot multiple time the router. Disable the ddns and reenable it. Still the same.
I have the RT-Ac87U with merlin's latest.
EDIT: My internet seem fine. No downtime nor slowdown.
Hi psyc0ld,
I'd like to guess this may caused by dns cache sync.
If you only tested with a single device, I'd like to suggest you to try these depanding on different OS:
[Windows based devices]
I> Overall
1. run Command prompt
2. type "ipconfig /flushdns" then enter.
3. you should see "Successfully flushed the DNS Resolver Cache."
II> Chrome
1. put "chrome://net-internals/#dns" on your navigation bar, enter, and click "Clear host cache" button.
[Linux]
I> dnsmasq
1. sudo /etc/init.d/dnsmasq restart
II> nscd
1. sudo /etc/init.d/nscd restart
III> bind server
1. /etc/init.d/named restart
Good luck,
Cheers.
W.Hak
Thanks for your replie, I'm on mac actually. But I'll try with a different mac and I'll report back.
I just found the command for mac, I'll test more.
No luck. I've enter the command from the apple support site without any luck. I still get my old ip address when I tried to ping my ddns address.
xxx:~ $ nslookup xxx.asuscomm.com
Server: 192.168.0.1
Address: 192.168.0.1#53
Non-authoritative answer:
Address: 107.179.155.111
xxx:~ xxx$ nslookup xxx.asuscomm.com 8.8.8.8
Server: 8.8.8.8
Address: 8.8.8.8#53
xxx:~ $ nslookup xxx.asuscomm.com 8.8.8.8
Server: 8.8.8.8
Address: 8.8.8.8#53
Address: 69.165.xxx.xxx
Code:xxx:~ $ nslookup xxx.asuscomm.com Server: 192.168.0.1 Address: 192.168.0.1#53 Non-authoritative answer: Name: xxx.asuscomm.com Address: 107.179.155.111 xxx:~ xxx$ nslookup xxx.asuscomm.com 8.8.8.8 Server: 8.8.8.8 Address: 8.8.8.8#53 Non-authoritative answer: Name: xxx.asuscomm.com Address: 107.179.155.111
I get both my old ip address.
But, 1 min later just to make sure.
This is my actual ip address..Code:xxx:~ $ nslookup xxx.asuscomm.com 8.8.8.8 Server: 8.8.8.8 Address: 8.8.8.8#53 Non-authoritative answer: Name: xxx.asuscomm.com Address: 69.165.xxx.xxx
psyc0ld this has to do with your DNS configuration and is not related to the Asus DDNS service. You might want to try and change DNS servers to Google's or OpenDNS ones and as you said give it sometime. Also try it on a PC or laptop if possible and see if the result is the same. If you have Android or idevice try it there as well and compare the results you get.
Hi everyone,
Try switching to a different DDNS name, then switch back to your old one, to see if it might force a refresh
Thread starter | Title | Forum | Replies | Date |
P | asuscomm.com | ASUS Wi-Fi | 6 | |
Asuscomm DDNS problems last days? (AX88U) | ASUS Wi-Fi | 10 | |
J | I can still access my router via a deregistered DDNS | ASUS Wi-Fi | 2 | |
RT-AX88U Pro - DDNS has been registered + Asus Android App | ASUS Wi-Fi | 3 |
Welcome To SNBForums
