Builder71
I've just tried out 4.266.23b and realized my network throughput has reduced speeds.
For instance, before loading the firmware, I was able to get speeds approximately 20+mbps from speedtest.net. After updating the firmware, speed test shows around 12+ mbps.
Why has the speed reduced in all the devices I've tested?
** Note my devices and speedtests are only on 2.4ghz, WPA-Personal authentication method before & after the firmware upgrade. 5ghz has been disabled, transmit power & channel same as before upgrade **
I'm on a 50/50 fiber connection, no issues with speedtest.net
Same indication as always. (close to 50/50)
