3006.102.5 Beta 1 is now available for all supported models. The focus of this release is the merge of updated GPLs, and the implementation of a new System Log -> Connection interface. Asus also migrated the RT-BE92U to the same codebranch as other Wifi 7 models.
Changelog:
Please keep discussions on this specific release. Off-topic posts will be either ignored or deleted, depending on my mood at the time.
Downloads are here.
Changelog is here.
Changelog:
3006.102.5 (xx-xxx-2025)
- NOTE: For developers, please note that the new default branch
is now called "main" - it's what was previously the
3006.102 branch.
The "master" branch has been renamed "master-old", and
is no longer actively used. Due to how the 3006.102
branch diverged, it was easier to do it this way than
to fold back 3006.102 on top of master.
- UPDATED: Merged GPL 3006.102_37957 for Wifi 6 devices.
- UPDATED: Merged GPL 3006.102_38757 for WIfi 7 devices.
- UPDATED: dropbear to 2025.88.
- CHANGED: Reworked System Log -> Connections page. You can
now filter the list, local hostnames are resolved,
automatically refresh the page, and IPv6 is supported.
- CHANGED: Replaced netstat-nat by a fork called netstat-nat-ng.
This fork fixes a number of issues with IPv6 and
field size.
- CHANGED: Updated Control-D DoT server entries (dave14305).
- FIXED: OpenVPN server set to "Internet only" would fail to
block LAN access (invalid firewall rule from SDN was
bypassing it).
- FIXED: DNSDirector "Router" mode would not always work properly
with IPv6 (now uses REDIRECT instead of DNAT, which was
backported from iptables 1.4.19).
Downloads are here.
Changelog is here.
