Webfanatic
I am having problems with latency (lag) with my PS4 since installing this firmware update. No problems before with the .40_alpha4 build. Gaming is lagging whereas wasn't before. Friends from my same area are not experiencing lag so its not a connection ISP issue.
Maybe just a coincidence? All my settings are the same. Any settings i should put to make gaming more optimal? Or should i downgrade back to the old firmware.
Also, why is it PPPoE username and password not saved? Everytime i go back in to check it, it says "useradmin" and the username and some seemingly random generated password. Is this a security feature?
Thanks in advance.
Thanks in advance.
