Why did the problem appear only with version 386.1_2? By the way, there is no solution.![]()
'Router running low on free NVRAM' yellow alert notice
I'm getting the blinking 'router is running low on free NVRAM' light on my AC68U. There are 10 reserved DHCP addresses and a second AiMesh device. Below are the usage details to aid /w diagnostic. Is it OK to ignore the blinking light? Firmware: 386.1 NVRAM usage 62650 / 65536 bytes size...www.snbforums.com
You answered your own question, last sentence.Have problems with WiFi 5Ghz on my RT-AX86 with Merlin 386.1 and 386.1.2. It’s working for a couple of days and then disconnect. When I try to connect to 5Ghz it’s always saying it is wrong password. If I change firmware between 386.1 and 386.1.2 it is working again and not complaining about wrong password. Think it’s no problem with 2.4 ghz. Haven’t done any hard reset. Just dirty flashing.
Yay! I got my AX88U back from repair. Got it all set up with 386.1_2, works perfect with AIMesh now, among other things. Thanks to @RMerlin for planting the seed in my head to get the router looked at. It was replaced not fixed. Does anyone know the CLI command to retrieve the hardware version on this router?
So, is there any instance where upgrading FW does not require a Hard Reset?You answered your own question, last sentence.
My expectations are very high, so I'll take that as "always hard reset"@ottofreud yes, when the network is working as expected.
At a guess, Asus' security daemon. If you save to /jffs/addons do you see the same deletion?Since the new firmware all files and the directory with the name update are deleted after 24 hours.
Is this a bug or intend to work this way?
First I though I had a bug in my script: https://github.com/wbartels/IPSet_ASUS_Lite/issues/2
But even a directory outside skynet was deleted after 24 hours, for example /tmp/test/update/
Can tel you after 24 hours.At a guess, Asus' security daemon. If you save to /jffs/addons do you see the same deletion?
Hi Everyone: I have installed the 386.1 as well as 386.1.2 on my AX88U router, I have even performed a factory reset after installing the firmware. The problem is i keep on getting the following error message. I was just wondering if this is normal or should I be worried. Everything about the router works fine, it's just that this error message is new to me.
It is because of guest mode wireless. Ignore or don't use it. Asus issue I guess.Hi Everyone: I have installed the 386.1 as well as 386.1.2 on my AX88U router, I have even performed a factory reset after installing the firmware. The problem is i keep on getting the following error message. I was just wondering if this is normal or should I be worried. Everything about the router works fine, it's just that this error message is new to me.
Thanks for the clarification!It is because of guest mode wireless. Ignore or don't use it. Asus issue I guess.
After 24 hours:At a guess, Asus' security daemon. If you save to /jffs/addons do you see the same deletion?
Welcome To SNBForums
