Hi
After update to 376.48_1 I didn’t have any access to my own NAT server
by DNS and as always issue with IPv6 (I’m not familiar with Comcast
After I went back to 37.6.47 everything is fine (DNS and
IPv6)
Thanks.
Bump on the nat-loopback DNS issue.. accessing by local webserver by
http://home.webserver.com no longer works and only accessible by
http://10.0.0.x
Same with all other services, not just http.
From outside it works fine.
I'm guessing Merlin has updated with some of the newer Asus source, thus introducing this bug.
This bug appeared in a recent asus firmware, not sure if it ever got resolved (it was mentioned on SNB forums, but no one seemed to have an answer) and was the reason I moved over to Merlin full time - and tbh, even though I'm gonna roll back (to Merlin firmware) to sort the issue, Great job Merlin.
I'm on an N66U btw, but I'm guessing this bug affects all
EDIT **
Seems NAT acceleration WAS turned on - Turning it off solves the problem. Did 48 turn this on, or did I turn it on in my sleep (which wouldn't surprise me!)
If you're wondering where the switch is: LAN/SWITCH CONTROL
I didn't do a factory reset.. but it seems NAT ACCEL was enabled - and also 5Ghz was enabled. Maybe factory reset would have been fine.
Maybe this only effecting certain routers? Mine's an N66U but I see posts saying AC66 updated fine.
Merlin, why did recent Asus firmware als have similar issue, or did they force NAT accel on? Just curious when spontaneous issues like this appear.
Again, Thanks
